LinkBack (13) Thread Tools Display Modes
Old 26-02-2011, 09:11 PM   13 links from elsewhere to this Post. Click to view. #1 (permalink)
Just Do It
Charley's Avatar
Default Use Samsung Galaxy Ace to connect to Internet through PC
How can I use Samsung Galaxy Ace to connect to Internet through PC? I have a Dataone Broadband connection.
Charley is offline   Reply With Quote
Old 26-02-2011, 09:14 PM   #2 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Default Re: Use Samsung Galaxy Ace to connect to Internet through PC
You'll need a wireless router for that...
AndroidFan is offline   Reply With Quote
Old 26-02-2011, 09:18 PM   #3 (permalink)
Just Do It
Charley's Avatar
1. How can I use it on Dataone Broadband ADSL connection ?
2. How much will this cost ? A cheap one will do.
Old 26-02-2011, 09:25 PM   #4 (permalink)
What type of modem do you have ? If you have taken the modem from BSNL, then it should be either of type1, type2, type 3 or type 4 out of which type2 & type 4 has Wifi. (see if your modem has an antenna in the back)
Else you can get a cheap router for about 1.5k
pauldmps is offline   Reply With Quote
Old 27-02-2011, 01:22 AM   #5 (permalink)
Peak Oil is real!
AndroidFan's Avatar
You can get a cheap Belkin wireless router for around 1.2k in local shops. On ebay, it is available for Rs 1065 with free shipping -- eBay India: Belkin G Wireless Broadband Router - 54Mbps - 5Yrs Wty (item 150559788086 end time 09-Mar-2011 15:18:13 IST)
It is relatively easy to set up a router. I use a wired Reliance broadband connection. A year ago, I got a router so that I could share internet another laptop and an iphone.
Google it... You will find all the tips you need...
Cheers!
Old 27-02-2011, 09:50 PM   #6 (permalink)
Just Do It
Charley's Avatar
Please see the screenshot. It doesn't have an antenna
What do you suggest ?
---------- Post added at 04:20 PM ---------- Previous post was at 04:19 PM ----------
My PC doesn't have a WIFI adapter. Should I buy that in addition to the Wireless Router ?
Old 27-02-2011, 10:39 PM   #7 (permalink)
^^ You just need a wireless router. You can connect your PC via Ethernet (as it is now connected). No need for a Wifi adapter.
Old 28-02-2011, 04:06 PM   #8 (permalink)
Just Do It
Charley's Avatar
1. Can I use a wireless modem instead of adding the wireless router with the exisiting wired modem, so that I can use the Dataone wired broadband as well as mobile WIFI at the same time ? [Kindly note I don't have a WIFI adpater in my PC]
2. If yes, is it better to buy the wireless modem from BNSL or a 3rd party ?
3. What did you mean by Type1, Type2, Type3, Type4 ? Please explain.
Old 28-02-2011, 04:42 PM   #9 (permalink)
There are two things which you can do.
1) Get a Wifi router and use your ADSL modem with it. The Ethernet cable from your ADSL modem goes into the Wifi router which shares the internet through Wifi. Wifi routers also have LAN ports so you can connect your PC through LAN too.
[You used two devices here]
2) Get a Wifi router with built-in ADSL modem and ditch your current ADSL modem. Telephone line goes in your Wifi + ADSL router, Wifi network is created and once again connect your PC with LAN.
[You used a single device here and this is what I will suggest to avoid hassle]
I will not suggest to go for a Wifi + ADSL modem from BSNL. They are subpar in performance.
Linksys WRT54G2 - only Wifi router with 4 LAN ports. It will cost you 1.5k
Linksys WAG54G2 - Wifi + ADSL router with 4 LAN ports. It will cost you 2k [I use this at home]
Old 28-02-2011, 05:44 PM   #10 (permalink)
3. Those are just types of modems (+router) supplied by BSNL.
Type 1 - 1 Ethernet port + 1 USB port + no Wifi
Type 2 - 1 Ethernet port + 1 USB port + Wifi
Type 3 - 4 Ethernet ports + no USB ports + no Wifi
Type 4 - 4 Ethernet ports + no USB port + Wifi
Old 28-02-2011, 05:51 PM   #11 (permalink)
Just Do It
Charley's Avatar
Does this have USB also ?
Old 28-02-2011, 05:53 PM   #12 (permalink)
No it doesn't. Infact I have never understood why people use USB with their routers. Ethernet is the best.
Old 28-02-2011, 06:06 PM   #13 (permalink)
Just Do It
Charley's Avatar
I called Golcha Computers, SP Road now. They said those models are not available now. But these are the ones available [Wifi + ADSL router]
Linksys WAG120N - Rs. 3000 Excluding Tax
Dlink DSL-2640u - Rs. 2000 Excluding Tax
Old 28-02-2011, 06:52 PM   #14 (permalink)
is it enough for mobile? i mean share PC's broadband with mobile. just for browsing sometimes.
Sam is offline   Reply With Quote
Old 28-02-2011, 07:21 PM   #15 (permalink)
Linksys WAG120N is Wifi-N which is 104mbps WLAN.
Dlink DSL-2640u is Wifi-G which is 54mbps WLAN.
The choice is yours.
Regarding Linksys WAG120N, Liverpool_fan has one and he isn't satisfied with it due to firmware glitches. No idea if they are sorted or not. But personally, I am more than satisfied with my WAG54G2.
---------- Post added at 07:21 PM ---------- Previous post was at 07:19 PM ----------
BSNL charges you 1.5k for the Wifi version iirc. It is better to shell out 0.5k more and get a proper router from outside. The BSNL ones have really bad range.
Old 28-02-2011, 07:49 PM   #16 (permalink)
will take BB in a few days & most probably will take the modem on rent. so buying a router doesn't seem to be the best idea. if i do go for a router, it'll be after a few months.
Old 28-02-2011, 08:47 PM   #17 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Do this.
As for WAG120N, great reception and performance as a Wireless Access Point.
Sadly for WAG120N the downsides are:
- Firmware issue regarding ADSL Gateway, ADSL sometimes/sometimes not automatically connects and this frankly sucks. Could be the case that my piece is defective, haven't bothered with RMA.
- No DHCP Reservation. i.e. can't bind IPs to a particular MAC address.
- No telnet into the router host.
Apart from that now I have connected my WAG120N to my ADSL Gateway router (Betel 220BXI) on LAN port 1 and PC as wired on LAN port 2. Works really well for me, the reception is great all over my house.
I would suggest you to get really separate ADSL Gateway (or even use your existing modem) and Wireless Access Point (they'll cost 2k or below, get an OpenWRT compatible device).
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/137257-use-samsung-galaxy-ace-connect-internet-through-pc.html
galaxy ace modem pc - Virgilio Ricerca Web This thread Refback 24-09-2011 05:48 PM
Thread Use Samsung Galaxy Ace to connect to Internet through PC | Digit Forum | Page 2 | BoardReader This thread Refback 31-08-2011 10:12 PM
Samsung Galaxy Ace Wifi Router | N Android update 2011 2012 This thread Refback 25-06-2011 01:31 PM
Thread internet problem in galaxy ace | Digit Forum | BoardReader This thread Refback 07-06-2011 01:30 PM
Samsung Galaxy Ace Connect To Pc | Computer Review & Tips This thread Refback 24-05-2011 07:48 PM
How To Connect Internet From Samsung Galaxy Ace On Pc | Computer Review & Tips This thread Refback 23-05-2011 07:30 PM
Galaxy Ace As Modem Pc | Computer Review & Tips This thread Refback 23-05-2011 12:21 AM
Galaxy Ace Connect To Pc | Computer Review & Tips This thread Refback 21-05-2011 11:23 PM
Use Samsung Galaxy Ace To Connect To Internet Through Pc Digit | Proxy Blog | Free Proxy List | ProxyRoller.com This thread Refback 21-05-2011 10:17 AM
DataOne - internet discussions | BoardReader This thread Refback 20-04-2011 11:57 PM
How To Connect My Samsung Galaxy Ace To My Wifi | Proxy Blog | Free Proxy List | ProxyRoller.com This thread Refback 14-04-2011 11:54 PM
Samsung Galaxy Ace Wifi Cant Connect | Proxy Blog | Free Proxy List | ProxyRoller.com This thread Refback 06-04-2011 08:12 AM
Thread Use Samsung Galaxy Ace to connect to Internet through PC | Digit Forum | BoardReader This thread Refback 03-04-2011 12:35 PM
