Old 22-02-2011, 07:01 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Smile Basic Mobile for Net Purpose.
I've a 'Dell Inspario 15' lappy n Docomo conn. having net activated on it.
I want a decent phone just 4 net purpose.
It may b frm any gud brand but prefered ones r frm - SE,Nokia n Samsung.
It shud av gud battery lyf n shud b compatiable vid lappy.
My budget is upto 2K to 2.5k , Bt can b extended strictely upto 3K only.
Thanks a lot for ur kind suggestions.
Hope 4 d best n Do d right :)
reddick is offline   Reply With Quote
Old 22-02-2011, 07:28 PM   #2 (permalink)
Default Re: Basic Mobile for Net Purpose.
In that budget, you'll get only a GPRS handset. If you plan to get a 3G connection later, you'll have to buy another phone.
Get a phone which supports USB-charging. This is crucial because tethering drains too much battery.
Avoid Nokia because Nokia phones do not have USB charging. Get a low-end Samsung.
Alternatively, you could buy those USB dongles (available from brands like Micromax & Beetel) & put you sim-card int it, if you don't plan to use it for calling.
If you want a future proof solution (with 3G), you can get the SE Cedar for 5k. which supports HSDPA upto 7.2 Mbps OR the Nokia C3 for WiFi.
pauldmps is offline   Reply With Quote
Old 22-02-2011, 10:58 PM   #3 (permalink)
Mobile Freak
reddick's Avatar
Okay , Do u knw any Samsung phone in dis category? N does those usb dongles r gud alt. 4 phone , wht's r their prons n cons n hw much they cost?
Old 22-02-2011, 11:25 PM   #4 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Huewei UMG1831 @ Rs 2500 - 2700.
Supports upto 21mbps 3G.
pros - No Battery, Cheaper etc
cons - Not a phone.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 23-02-2011, 10:07 AM   #5 (permalink)
Any Metro or Guru series phone should do. But as I said it is better to get a USB dongle as it supports 3G too (if you upgrade later) & doesn't require extra battery. Also it is convenient as compared to connecting a cable to a phone.
Old 23-02-2011, 11:07 AM   #6 (permalink)
Believe Me or Not!!!
3G speed comes with unpleasing price tag...
If this isn't a problem surely go for USB dongle...
Otherwise phones suggested by paul would serve you well, atleast for browsing (not downloading stuff)
NainO is offline   Reply With Quote
Old 23-02-2011, 12:03 PM   #7 (permalink)
Mobile Freak
reddick's Avatar
Hmmm
Okay then , I'l go through these USB dongles available in mrkt n tell u guys later.
I think d dongles r gud as I dnt wana call or sms. I've phone with other conn. 4 tht
U guys help a lot .. Thx all
