Old 16-02-2011, 03:24 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
wid million core procesor
davinci's Avatar
Unhappy Urgent!!!!Pls hlp wid my LG Optimus One
Last night I tried to take a back up of the rom of my new optimus one(using the app ROM manager) because i wanted to install Honeycomb in it.Bt the process didnt complete and only the start up screen showing the LG logo was flashin....i removed the battery as i couldnt shut it down but nothing changed as it is not starting....whenever i try to switch it on it jst shows the LG screen untill the battery is drained off............pls help me...what should i do now???
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
davinci is offline   Reply With Quote
Old 16-02-2011, 04:08 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Urgent!!!!Pls hlp wid my LG Optimus One
you need to flash it with stock ROM. did you get any sync suite to install on a PC? check if you have an option to reinstall firmware using LG PC Suite.
desiibond is offline   Reply With Quote
Old 16-02-2011, 04:28 PM   #3 (permalink)
rom manager have problem with optimus one. try nandroid backup next time onwards. for now, flash a stock rom with kdz updater. go to XDA forum's P500 thread. theres a topic about the recovery of bricked mobiles(sticky thread). go to last or last 2nd page & read the first post. your mobile should be back to normal.
BTW, honeycomb for mobile? where you found it?
PS: if you don't know how to modd or play with your mobile safely, better stick to the stock rom.
Sam is offline   Reply With Quote
Old 16-02-2011, 09:52 PM   #4 (permalink)
davinci's Avatar
tried doin it wid kdz bt da firmwire i dwnloaded from xda link is a .dz file n is nt recognised by kdz.....pls hlp
Old 17-02-2011, 01:23 AM   #5 (permalink)
The extn should be .kdz ...
Download file from here
csmg.lgmobile.com:9002/swdata/WEBSW/LGP500/AINDHW/V10b_00/V10B_00.kdz
Also, if u have made partitions on ur sd card, delete partitions and format it before flashing ... And u were trying to install gingerbread right ?...
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline   Reply With Quote
Old 18-02-2011, 09:09 AM   #6 (permalink)
Joker
Posts: n/a
^^ link is not working.
Old 19-02-2011, 11:11 PM   #7 (permalink)
davinci's Avatar
the working link is
http://csmg.lgmobile.com:9002/swdata...00/V10B_00.kdz
finally fixed my mobile thak you sam n k4ce 4 hlpin a lot
Old 20-02-2011, 12:05 AM   #8 (permalink)
nice. but do tell us what steps you followed. may help others.
Old 20-02-2011, 04:16 PM   #9 (permalink)
davinci's Avatar
after downloading da firmware from the above posted link i just folled the instruction given in da following link
The LG Optimus One P500 Blog: How to flash Original Firmware on the LG Optimus One P500.
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/136941-urgent-pls-hlp-wid-my-lg-optimus-one.html
Thread Urgent!!!!Pls hlp wid my LG Optimus One | Digit Forum | BoardReader This thread Refback 22-07-2011 03:33 PM
