Old 11-02-2011, 07:48 PM   #1 (permalink)
manishjha18's Avatar
Default iphone 4 unlock
hi
do we need a unlock for iphone 4 bought from usa if somebody is using here in india under vodafone service....
knock kncok
http://drmanishjha.wordpress.com/
manishjha18 is offline   Reply With Quote
Old 11-02-2011, 10:35 PM   #2 (permalink)
Default Re: iphone 4 unlock
it depends if you bought the iphone in USA through AT&T or you bought it factory unlocked ....
if your answer is the latter, no unlock needed ... if your answer is the former, yes, you would need to unlock it ... and depending on your baseband and OS version, the unlock may or maynot be available ...
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline   Reply With Quote
Old 12-02-2011, 12:29 AM   #3 (permalink)
yeah bought from AT&t store.....so have to wait for unlock...
this is bad..still no unlock for iphone 4..
Old 07-03-2011, 12:26 PM   #4 (permalink)
Yes the unlock codes are not available for Iphone 4 of US networks. But i've seen many sites which have for other country networks.
jothsha88 is offline   Reply With Quote
