LinkBack (2) Thread Tools Display Modes
Old 07-02-2011, 02:20 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Angry Hard Reset Samsung i5510
I have purchased samsung i5510 a month ago. All was working fine but as I have changed lots of settings of phone, I thought to reset it to default factory settings.
But now when I switch on my Phone nothing happens only Samsung logo keep flashing
I tried different method to hard reset my phone like Vol + Home + Power and so on..
Please provide me with a working method to hard reset my phone
pranavalw is offline   Reply With Quote
Old 07-02-2011, 02:45 PM   #2 (permalink)
Default Re: Hard Reset Samsung i5510
take it to samsung authorized service centre
rsk11584 is offline   Reply With Quote
Old 07-02-2011, 07:10 PM   #3 (permalink)
I think it is vol. down + power + centre key
pauldmps is offline   Reply With Quote
Old 14-02-2011, 12:08 PM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
I'm also facing a similar issue where someone else messed with pattern lock and now i want to do a factory restore but I am unable to access any options on the phone.
If someone knows way of doing a factory restore pls reply.
rakeshishere is offline   Reply With Quote
Old 14-02-2011, 12:26 PM   #5 (permalink)
If you can access the dialer, then try this code: *#*#7780#*#* or this:
* 2767 * 3855 #
Old 15-02-2011, 07:48 AM   #6 (permalink)
HELP AND SUPPORT
No dialer option available
I got the "Too many pattern" attempts problem on the phone and its like a brick past 2 days. I think i might end up going to service center
Old 15-02-2011, 08:12 AM   #7 (permalink)
Try pressing vol. down + centre button + power button together. If that does not work, try vol. down + menu key + power button.
Old 15-02-2011, 06:42 PM   #8 (permalink)
why need title?
bharathbala2003's Avatar
Download the firmware from samfirmware (either the 2.1 or the 2.2 if u want) and use odin to flash it on ur phone.. also il upload the opa file that i got from a website which i used to flash 2.2 on my cousin's phone
[edit] i ve found that website link.. use the procedure in this link.. it works like a charm.. i flashed 2.2 but u can flash 2.1 if u want
Link
bharathbala2003 is offline   Reply With Quote
Old 16-02-2011, 09:32 AM   #9 (permalink)
HELP AND SUPPORT
Thanks .. finally fixed it :-P It was a brick for 72hrs
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/136694-hard-reset-samsung-i5510.html
Hard Reset Gt I5510 This thread Refback 11-02-2012 11:03 PM
Hard Reset I5510 This thread Refback 05-02-2012 06:35 PM
