Old 28-01-2011, 02:30 AM   #1 (permalink)
dhan_shh's Avatar
Wink # Airtel 3G - Howzzat?
At last,
Airtel 3G came to Chennai,
Tariff is very expensive when you compare with BSNL,if you go by 'pay as you use'......30ps/20kb (remember bsnl 3G charges are ONLY 1ps/10kb)
If you want to select 2GB plan valid for 30 days then Airtel 3G charges Rs.750 and BSNL 3G charges Rs.716,
Speed Test.net is NOT very reliable when it comes to Mobile broadband checking,but still says only this:
But,overall mail checking,browsing looks definitely faster (I hope it is not imagination!)
Share your Views!
Expect the Unexpected !
dhan_shh is offline   Reply With Quote
Old 28-01-2011, 07:24 AM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: # Airtel 3G - Howzzat?
Tariff plan suck big time. BSNL has Rs 4200 for 6months. Unlimited without hidden limits.
Thats only 700 p/m.
Also I've seen 4-5mbps speeds in BSNL 3G with speedtest.
Ishu Gupta is offline   Reply With Quote
Old 28-01-2011, 12:08 PM   #3 (permalink)
I am using MTNL in delhi but i want to switch with BSNL how can i switch on BSNL i want some good kinda offers that only i get from BSNL...
kiddish is offline   Reply With Quote
Old 28-01-2011, 12:50 PM   #4 (permalink)
Ishu Gupta's Avatar
Buy a BSNL 3G sim from outside of NCR and get a 3G data plan that has zero roaming charges. You will get 3G in delhi at the low BSNL prices (but low MTNL speeds).
Otherwise no BSNL in delhi.
Old 01-02-2011, 05:57 PM   #5 (permalink)
dhan_shh's Avatar
Many variation in 3G speed of Airtel,
On an average,its 1Mbps
Now,comparing with Chennai BSNL 3G,which is really good ONLY if you have a well ventilated room or outerspace,
If you are held up inside a room,with poor signal speed deteriorates:
Airtel 3G is far better whether you are inside a room or travelling out,speed remains reasonably good! (But,why the hell they are advertising 21Mbps!!!!!!! GOK)
Old 01-02-2011, 08:25 PM   #6 (permalink)
Ishu Gupta's Avatar
I think renovating your room (with more ventilation) is cheaper than Airtel 3G.
Airtel
Rs 2000 for 14GB
BSNL
Rs 1499 for Unlimited (No FUP)
MTNL
Rs 1800 for 100GB
Obvious why I won't get Airtel 3G.
And they are advertising 21mbps because their towers are capable of 21mbps. Most phone don't support more than 7mbps (not even the 30k phones). And speeds depend on the number of user connected per tower.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Old 02-02-2011, 12:20 PM   #7 (permalink)
my precious
Gollum's Avatar
@ishu
are you located in noida or somewhere else?
Gollum is offline   Reply With Quote
