Old 05-01-2011, 01:13 PM   #1 (permalink)
Exclamation android PC suit capabilities?
hey all !
i am presently using symbian S60 device [nokia 5233]. the only thing i love about it the PC suit which allows me to send/read msgs right on the laptop after connecting via blue-tooth.
i am planning to shift to android. all i want to know is does android phones have PC suit which allow me to do the same ? i.e. handling messages right from the laptop itself ?
please reply ..
thanks in advance!
Amit Dutt
amit dutt is offline   Reply With Quote
Old 06-01-2011, 01:20 PM   #2 (permalink)
sriharsha_madineni's Avatar
Default Re: android PC suit capabilities?
There is no particular PC-suite for Android as such. Although a few third party pc suites have popped up recently, I haven't tried them, so can't comment on that.
If you are worried about sending messages from Laptop via Phone, then there are numerous apps to take care of that
One such app is "SMS Control Center"
More info here
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now   Reply With Quote
Old 14-01-2011, 09:44 PM   #3 (permalink)
thanks for info. can i take msgs and contacts backup on pc ?
Amit Dutt
Old 15-01-2011, 11:00 AM   #4 (permalink)
you can use my phone explorer software with android phone its awesome you can browse phone, sd card , send receive messages , and take back up of contacts also
MY PHONE EXPLORER www.fjsoft.at/
rsk11584 is offline   Reply With Quote
Old 15-01-2011, 04:44 PM   #5 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i use some sms backup and restore software to take backup in xml format
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline   Reply With Quote
Old 15-01-2011, 05:16 PM   #6 (permalink)
Of-course you can, there are apps which export your contacts and sms into required formats.
For contacts, since everything is in sync with Gmail, you can import them from gmail itself, no need of any app.
