Old 04-01-2011, 02:55 PM   #1 (permalink)
Default A phn within 8k?
Can any1 help
how's the Samsung S5250 Wave525 - Full phone specifications
its for a frnd
he wants d basics
gud battry
reliability
easy sms input
loud spkrs
& a nice cam
raj_in is offline   Reply With Quote
Old 04-01-2011, 04:46 PM   #2 (permalink)
Default Re: A phn within 8k?
The Wave 525 lacks 3G. So if your friend can live without it, then its a good buy.
I'll suggest Nokia C5.
pauldmps is offline   Reply With Quote
Old 04-01-2011, 08:45 PM   #3 (permalink)
utkarsh009's Avatar
^^best choice if you need a basic phone.
utkarsh009 is offline   Reply With Quote
Old 04-01-2011, 09:34 PM   #4 (permalink)
Believe Me or Not!!!
If touch screen is mandatory and texting is on heavy side its better to go for Samsung Wave 533, feature-wise it's same as Wave 525 but with a added QWERTY keypad and price increment of 1k.
Otherwise consider Nokia c5 (small screen) or Sony Ericsson Zylo (no 3.5 mm audio jack)
NainO is offline   Reply With Quote
Old 04-01-2011, 09:55 PM   #5 (permalink)
i also dnt knw y samsung ddnt put 3g in them
he is keen on touchscreen
orelse c5 best in this range by far
Old 04-01-2011, 11:40 PM   #6 (permalink)
to keep the price low. cause if they add 3G, price may rise as high as 12k. almost same as Galaxy 551. & at that price, most will go for Android rather than some BADA.
Sam is offline   Reply With Quote
Old 05-01-2011, 12:03 AM   #7 (permalink)
Buy Samsung Wave 575 S5753: Price, Reviews: Flipkart Mobiles
after a lil exploring found this....
any othr tounch screen in this range
bcz i found none...
xpct d wave serise...
Old 05-01-2011, 12:16 AM   #8 (permalink)
anand1's Avatar
Nokia C5 and X3 is the best. If you need touchscreen and almost every feature then go for Samsung mobiles at this range. But you have to cmpromise the 3G connectivity.
Technology On The Fly
anand1 is offline   Reply With Quote
Old 05-01-2011, 02:06 AM   #9 (permalink)
for around 8k, the top 3 picks from my side:
1. Samsung Wave 533 (no 3G but slide out QWERTY)
2. Samsung Wave 575 (cause of 3G)
3. Samsung S5620 Monte (if you hate the wave mobile looks & name).
yes the nokia are always there. but i feel its time to let them rest.
Old 05-01-2011, 11:55 AM   #10 (permalink)
would u guys recommend d galaxy5 if he can extnd d budget by 1k
only 2 cons i can find 2.8inch screen & 2mp cam
Old 05-01-2011, 03:15 PM   #11 (permalink)
If u wang 3g, then get what sam and raj both stated wave575 or galaxy5 if u can do with a small screen. 3g connectivity if nt required then ur choice wave 525 is good.
vishurocks is offline   Reply With Quote
Old 05-01-2011, 05:59 PM   #12 (permalink)
Why not get the Galaxy 5 for 500 bucks more ? Its much better than the 575 anyways.
Old 06-01-2011, 11:11 AM   #13 (permalink)
Point Blanc
and also in nokia there is
nokia 5235 - with 2 MP does not has the best camera just a decent one. pretty good with other features and battery.
I do not like X3 build and it does not has 3G
and if you value for longer use then I wont consider samsung wave phones with bada OS,
and +1 for galaxy 5, better go for it(and its ultra rich features) rather than thinking about its 2 MP camera
acewin is offline   Reply With Quote
