Old 01-01-2011, 10:22 AM   #1 (permalink)
Default Google Nexus S: 16 tips and tricks
Here's a round up of the secrets and tips you'll need to know to get the most out of your latest gadget, so read on to go from Android amateur to Nexus know-it-all.
1. Reclaim the comma
One of the first irritations you'll encounter with the Google Nexus S is the lack of a comma - the keyboard has a voice search icon where the oft-used symbol should be.
But there's a way to reclaim it - head into Settings, and choose Language and Keyboard. Tap Android Keyboard and in there you'll see a dropdown menu labelled Voice input.
From here you can select whether the voice search icon is on the front screen, the symbol menu or delete it altogether - and more importantly, the comma is back where it belongs.
2. Inbuilt battery graph
A massive problem for smartphones is the battery maintenance - so many devices have offered such poor battery life that some have been rendered virtually unusable.
The Nexus S isn't that bad in terms of holding its charge, but if you want to see what's happening with your battery, the phone comes with a battery graph built in.
Simply go into Settings, then tap About Phone. Open Battery Use and hit the smaller battery graph at the top - this then opens up into a fully-fledged graph complete with information on how fast your power depleted and what the phone was doing at the time.
3. Get rid of unwanted apps quickly
You probably know already how to uninstall applications on the phone in the menu system.
But this can take a while, and ultimately frustrate you into leaving some apps that you didn't reach.
But if you open up the Android Market, you'll see a Downloads tab that shows you everything you've nabbed from Google's portal.
Choose any of these and the option to Uninstall is present in the bottom right-hand corner - the list is easier to access and quicker to use, and you can give feedback to the developer on why you uninstalled it too.
4. Boost your media experience with Blu-ray DVD HD movies
The media experience on the Android 2.3 platform is unfortunately not that good natively - incompatibility with many file types and basic operation mar the experience.
For music, we recommend MixZing - it has all the features of the Android experience but also has Genius-like abilities to mix a playlist based on a single song choice, as well as a decent inbuilt EQ make it a real step up.
Tips: Users can use this Blu-ray Ripper to rip Blu-ray DVDs to Nexus S and the Video Converter to transcode any video formats to Nexus S for playback.
For movies, mVideo Player is the one we reach for instantly whenever we pick up an Android phone. The powerful player has a high level of file compatibility, multiple bookmark options and even a slider for brightness management.
You can even see the clock when viewing a video if you so wish - an oft-overlooked feature.
5. Unlock the power of voice
We mentioned we didn't like the voice input icon on the keyboard, but that doesn't mean we aren't fans of voice search.
From calling and navigation to text entry and Google searching, your voice can be activated by simply holding down the search key.
If you're already in an application (say text message editor) you can hit the icon to simply say your text - although you'd have to ask whether a phone call makes more sense at this point.
6. Stop the constant sipping
We've mentioned battery management earlier - and there's a way you can stop it plummeting downhill instantly.
If you head into the Settings menu and choose Accounts and Sync, there's a large checkbox for background data.
If you only periodically check things like social networks or email, then this is a great way to save some power, as you can get the same functionality by just manually updating when you open the app.
It does mean things like push notifications won't work, but if you're after a decent battery saving and don't care about instant updates, give this a go.
7. Go 3D with Google Maps
Google Maps 3D is here - well, for Cardiff and Birmingham in the UK. The new Google Maps 5.0 for Android is by far the most powerful offering so far, with the 3D vector view allowing you to zoom in and twist around certain cities from your mobile.
Other additional functions include compass orientation, for easier foot navigation, and offline caching, where the phone cleverly works out the places you frequent the most and downloads the date when you're on Wi-Fi and plugged in (ie on the nightly charge).
8. Unlock your file system
Although some phones (like the Samsung Galaxy S) include an inbuilt file management system, the Google Nexus S has no such functionality.
This means when you've copied media across to the phone but can't see it in the gallery you're pretty much stuffed - unless you download a file manager.
We're fans of Astro - not only is it ridiculously easy to fly through the folder branches, it can also unzip folders and search for file names - and it's free too.
9. Take a picture of yourself
One of the new features of Android 2.3 is a support for video calling, and to that end the Google Nexus S has a front-facing camera to facilitate it.
The problem is there's no mainstream application to let you call using the front VGA camera - but you can still use it to take pictures.
Simply fire up the camera and hit the camera switch icon in the bottom right-hand corner - you can take slightly gawpy pictures of your mug as quick as a flash.
10. Easier copy and paste
Android 2.3 comes with enhanced copy and paste, making it easy to just hold down a word and see it copied to the keyboard.
In text editing, you can cut or copy the word, and on the internet you simply need to long press on a phrase and drag the tabs to choose the selection you're after, with a quick tap auto-copying the text.
The tabs are now much larger and easier to manipulate as well, making it a much more simple experience when trying to move text from one place to another.
11. Check out the downloads
This might sound like a simple update, but there's now a dedicated application for items you've downloaded from the internet.
It saves you having to delve into the internet browser to get pictures or applications you've snaffled from the web, and delete them easily too.12. Bars to stop you scrolling
When you're running through a list and get to the bottom, sometimes you're not sure whether you've reached the end or if the phone is still loading more options.
Google has added in some orange flashes when you hit the top or bottom of a list as a visual cue - it's not the most piviotal upgrade, but it's certainly adds to the sheen of your phone.13.Magic tricks with photos
OK, not technically magic, but it certainly feels as cool as a card trick.
When in the gallery view, you already will know that the stacks of pictures mean there's more than one item in that category - but here comes the awesome part.
Put two fingers on the top of the stack, pull them apart and watch as the pics fly between your two digits - not only is it visually a veritable thrill, but you can easily see what's in there too.14. Access the special characters with ease
If you're after a bracket or @ sign, you don't need to faff about with the symbols section - simply holding down the full stop key will bring up a grid of them.
Simply slide up your finger to access new characters, including dashes, colons and the ever-popular + symbol.
If you do the same with the comma key (assuming you've moved it to the front screen) then this will also offer up and easy way to see the settings for the keyboard too.
15. Auto-correct supercharging
Google ushas ed the Android 2.3 upgrade to make auto-corrected typing a little easier: simply start writing a word, and when the autocorrect has an option, the space bar lights up to indicate you can confirm and use it.
If you've done this, but it's the wrong word, simply tap the offending selection of letters and the autocorrect options will spring back up too.16. Quick access to numbers and capitals
Using the multi-touch hardware doesn't just make it easier to type faster, it adds quick flick options for speed keystokers.
For instance: hold the shift key and press a letter and it will capitalise it without needing to enter the shift mode separately.
Or you can hold the symbol key down and use your other finger to hit the numbers - let go and the ABC keyboard springs magically back in
yao847zi is offline   Reply With Quote
Old 31-07-2011, 10:47 AM   #2 (permalink)
dharmil007's Avatar
Default Re: Google Nexus S: 16 tips and tricks
Thnx Man this was really HelpfUl
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 31-07-2011, 11:47 AM   #3 (permalink)
AJJU
azzu's Avatar
Thx man for the Share...
it would also help if u could mention the Source
I love and Live to Design
azzu is offline   Reply With Quote
Old 31-07-2011, 01:01 PM   #4 (permalink)
Nice find
I think this is the source
Old 01-08-2011, 11:30 AM   #5 (permalink)
Bad to the bone
amitabhishek's Avatar
Dude thanks for sharing but you should have given credit to the author. Google is a powerful tool people can quickly sniff out the source.
amitabhishek is offline   Reply With Quote
Old 01-08-2011, 11:37 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
umm. i think the OP is the author. am seeing the same post with him as author and in many forums.
PS: Please correct me if I am wrong.
desiibond is offline   Reply With Quote
Old 01-08-2011, 11:45 AM   #7 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Most of those things can be done on any phone running on stock Gingerbread... like my Optimus One...
CM7 FTW!
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
