Old 28-12-2010, 11:48 AM   #1 (permalink)
Exclamation Connecting to the Net using two Nokia Phones at once
I own two nokia 5130c-2 Xpress Music. I would like to know if there is any way to use both the mobile phones to connect to the Internet at the same time so that i will get double the speed. I use Windows 7 and can switch to linux if needed. Please suggest the whole procedure in a step by step approach since I am new to computers.
I have tried using nokia pc suite but it allows only one active connection at a time. Using standard dial-up connection and nokia pc suite at the same time won't work either. Please computer geeklords help me solve this problem. Isn't there any way i can combine both the connections.
Thanks in advance
sanderz178 is offline   Reply With Quote
Old 28-12-2010, 12:07 PM   #2 (permalink)
Default Re: Connecting to the Net using two Nokia Phones at once
Try using two standard dialups. It should work.
pauldmps is offline   Reply With Quote
Old 28-12-2010, 03:47 PM   #3 (permalink)
check my thread in tutorial section..
sushantvirdi is offline   Reply With Quote
Old 28-12-2010, 07:30 PM   #4 (permalink)
big thanks people..
Old 29-12-2010, 08:01 PM   #5 (permalink)
but can anyone tell me how can he get double speed >?
http://bugup.co.cc
tejaslok is offline   Reply With Quote
Old 29-12-2010, 08:30 PM   #6 (permalink)
^^ Two connections = double speed
