LinkBack (3) Thread Tools Display Modes
Old 11-12-2010, 01:15 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Nokia C5 VS Nokia 5230
The only place i go in for 5230 is because of its screen. Please let me know the best between the 2. I need mainly for GPRS browsing and Listening to music.
Nokia 5230
Key features:
* 3.2" 16M-color TFT LCD 16:9 touchscreen display (360 x 640 pixels)
* ARM 11 434 MHz CPU, 128MB RAM memory
* Built-in GPS receiver with A-GPS support; Ovi maps
Main disadvantages:
* Display has poor sunlight legibility
* 3rd party software is still somewhat limited
* Doesn't charge off its microUSB port
* No TV-out functionality
* No DivX/XviD video support out of the box
* Poor loudspeaker volume
Nokia C5
Key features
* Quad-band GSM/GPRS/EDGE support
* 2.2" 16M-color QVGA display, excellent sunlight legibility
* 3 megapixel fixed-focus camera with LED flash
* VGA video recording at 15fps
* Great audio quality
* Document viewer preinstalled
Main disadvantages
* Small screen
ripper is offline   Reply With Quote
Old 11-12-2010, 03:46 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Nokia C5 VS Nokia 5230
definitely 5230. C5 is for text and email junkies.
desiibond is offline   Reply With Quote
Old 11-12-2010, 03:52 PM   #3 (permalink)
pulkitpopli2004's Avatar
C5 i think --
moreover even you have given around more than 5 disadvantage in 5230 case..
and a T9 keypad phone will always have small screen if u'll compare it with touchscreen one..
pulkitpopli2004 is online now   Reply With Quote
Old 11-12-2010, 07:05 PM   #4 (permalink)
AJJU
azzu's Avatar
stating ur requirements will help us suggesting you a Good mobile...
coz both are two different Mobile's..
I love and Live to Design
azzu is offline   Reply With Quote
Old 11-12-2010, 08:14 PM   #5 (permalink)
Both the phones run the same OS. Hence, the software related disadvantages would be the same in both.
I'd recommend the 5230 as overall better than the C5.
pauldmps is offline   Reply With Quote
Old 12-12-2010, 12:19 AM   #6 (permalink)
Apart from Speaking in phone
I mainly use the mobile for
1. Listening to songs (i think 5230 is not Xpress music. I heard that we can add apps to increase the equalizers and play songs with 3rd party player where i can get good output)
2. Browsing to Gmail and Face book - may be maximum 1 hour per day.
3. Using Symbian apps
4. Camera occasionally.
Aspiration on 3G in these mobiles- High speed browsing at an affordable cost. Also to speak on video calls with your loved ones(so secondary camera may be useful(.. But i dont know what cost they will charge for this services initially.
My next mobile will be around 15 months from now or even earlier based on demand. So this phone will be used for that period. It will be a better smart phone around 15K budget.
Old 12-12-2010, 08:56 AM   #7 (permalink)
AJJU
azzu's Avatar
As per Ur your requirements in both The phones c5 wins the race.
but as ur budget is quite big i suggst u to go for a android mobile ,
eg : lg optimus 1 , gal 3 , dell..etc..
Old 12-12-2010, 12:34 PM   #8 (permalink)
Believe Me or Not!!!
C5 falls short only in screen size department - 3.2" vs 2.2". There is one inch screen increment in 5230.
But feature wise C5 is way ahead of 5230
Faster 600MHz proccy
HSDPA 10.2mbps
3.2MP camera with flash
Front cam for video calls
Moreover 5230 touchscreen isnt impressive.
NainO is offline   Reply With Quote
Old 12-12-2010, 10:29 PM   #9 (permalink)
So I think C5 will be a better choice.... My budget of 15K will be some 6 months or later based on my 2nd phone requirement may be for official (E5 or so) and i can use this one for personal (C5 - for 3G Video calls)
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/134927-nokia-c5-vs-nokia-5230-a.html
Yahoo! Canada Answers - Wich smartphone is better? This thread Refback 13-10-2011 07:12 PM
Wich Smartphone Is Better? 3G Mobiles This thread Refback 24-08-2011 08:45 PM
nokia c5 | BoardReader This thread Refback 22-12-2010 11:48 AM
