Old 09-12-2010, 06:02 PM   #1 (permalink)
Swimming, eh??
toad_frog09's Avatar
Default Need a phone around 5k.
So, like the title says, I need a cellphone for my sis.
I'm using mobile opera for surfing so cant fill the questionnaire, but i'l try to mention all the specific details.
My budget is 5k (+1.5-2k if its really worth it).
Display should be as big as possible in a bar/slide type, numpad cellphone. Absolutely no touchscreen. Qwerty keypad will do if that does not compansate with camera quality or user interface.
Currently, i'd put my stakes on symbian nokia, but if there's some model for reputed companies that provides better features with easy user-interface (definitely not samsung) then please let me know.
Connectivity, applications provided and camera should be top notch that'll be within my mere underwear budget, with more emphasis on camera (pixel, flash, bla bla) than former two.
The phone would probably be used for making calls and txting (dud!) apart from as a music player, camera, and possibly for surfing net.
I hope i gave enough info.
I dont have any phone pointed at as such so my research will start from scrach with help of you guys.
If you're posting something useful,thank you in advance.
If you stumbled upon here random clicking anywhere and have no valuable info as such, then dude, get a life.
I can never tell the difference between a man choking to death or a man beatboxing. So I always start dancing just in case.
toad_frog09 is offline   Reply With Quote
Old 09-12-2010, 06:58 PM   #2 (permalink)
Default Re: Need a phone around 5k.
^^ a good camera mobile with simply-to-use features & UI is Nokia X2. and for girls, who don't like fiddle with every avl setting or go on exploring all the hidden features, Nokia S40-S60 looks best.
Old 09-12-2010, 08:55 PM   #3 (permalink)
Swimming, eh??
can you list nokia models that come under my spec.
Old 09-12-2010, 09:55 PM   #4 (permalink)
pulkitpopli2004's Avatar
i wont suggest X2.. ma uncle purchased 1-2 months back.. this mobile hangs alot.. even w/o loading many apps or sumthing else..
in ur range in nokia - 6303i classic will be good.. or nokia c5(confirm its latest price m nt sure)
if u can move to samsung.. i have used Samsung Corby mate.. for ur sis it'll be a gr8 buy and also in ur budget.. picture quality in day time is definately better than oder 3megapixel.. bt lacks flash..
pulkitpopli2004 is online now   Reply With Quote
Old 09-12-2010, 10:12 PM   #5 (permalink)
AJJU
azzu's Avatar
Nokia c5 -Worth it (costs 7k appx), i Recently bought for my SIs...
looks cool ( white colored )
also check Micromax -q55 , girls love it though nt much of feature rich
I love and Live to Design
azzu is offline   Reply With Quote
Old 09-12-2010, 10:42 PM   #6 (permalink)
micromax wont support such apps for mobile.. go for c5.. best one for ur budget..
Old 10-12-2010, 12:09 AM   #7 (permalink)
Is Nokia C5 the best in its price range, no alternatives?
BlkRb0t is offline   Reply With Quote
Old 10-12-2010, 01:29 AM   #8 (permalink)
Swimming, eh??
^^^Same question.
What's it cost and is it worth?
Old 10-12-2010, 10:18 AM   #9 (permalink)
If you're looking for s60 based phone:
1. Nokia C5 - 3 MP camera without flash. I found the d-pad horrible to use (being extremely thin), other keys are large enough and comfortable to use. It will cost about Rs. 7500.
2. Nokia 5230 & 5233 - Both have almost same specs. except that the former supports 3g & gps, hence costs 1k more than the latter. The 5233 would cost about Rs. 6000. However, you've crossed out touchscreen, so these don't seem to be an option.
There aren't any other s60 based phone in this budget.
The best cameraphone in this price range would be the X2. It has a 5MP camera with LED flash. However, its keypad is dreadful for texting & its OS is Java-based s40.
You've crossed out Touchscreen as well as Samsung, which makes me unable to suggest you Corby phones. There aren't any phones in this price-range which satisfies all your needs (I have no idea about Indian brands so let others suggest them).
My recommendation would be to revaluate your needs & see which is the most important out of them. Then check below.
1. Best Camera - Nokia X2
2. Best app. support - Nokia c5, 5230, 5233
3. Best for texting - Nokia c3(s40, wifi, qwerty keypad) , Nokia c5
4. Big screen - Nokia 5230, 5233, Samsung Corby phones (touchscreen)
pauldmps is offline   Reply With Quote
Old 10-12-2010, 05:40 PM   #10 (permalink)
Swimming, eh??
^^^ok...
That was detailed enough.
While we are at it, can you name some cellphones from companies other than nokia that are user friendly and un-tacky...
Just to compare worthwhile products for best pick.
Old 10-12-2010, 07:00 PM   #11 (permalink)
AJJU
azzu's Avatar
Sony ericsson cybershot c510..is the phone ur sister needs as per the requirements u stated..
solid , good cam , great features.
c510
3G , cam : 3.15 MP, Autofocus, LED flash ,solid body , great music playing capabilities.etcc
vs
nokia c5
good build quality , 3g , gps , cam: 3.15mp , FIXED FOCUS . led flash .
No need to remind u that auto focus is damn superior to fixd focus cam (even if the MP counts are high)
now you decide which "c" to get ( c5 or c510)
if u get c5 u sacrifice on cam , while on c510 , GPS (and nokia fanboyism )
Old 10-12-2010, 07:11 PM   #12 (permalink)
Almost all foreign phone companies are trying their best to make the user-interface as easy as possible. (This is where the Indian brands need to concentrate rather than increasing the number of sim-card slots.)
The user interface on Samsung's Touchwiz as well as Bada are great. I am happy with my Samsung Champ (A review coming soon! on this forum)
The interface of new S60 phones have improved too but the functionality remains almost the same.
The Sense UI on HTC smart also looks great.
Old 10-12-2010, 08:50 PM   #13 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Get the C510.. Its a small iPhone with its awesome UI.. I am using it just fantabulous phone..
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline   Reply With Quote
Old 10-12-2010, 09:49 PM   #14 (permalink)
@OP .. if u will be indulged in installing apps and all dat sony C510 wont be a nice idea..in this case nokia c5 is gr8..
oderwise sony always gives a decent quality phone.. and definately go for C510
Old 10-12-2010, 09:54 PM   #15 (permalink)
AJJU
azzu's Avatar
i dont understand why it wont be a nice idea ?
Old 10-12-2010, 10:40 PM   #16 (permalink)
obv C5 is offering high battery life, more application can be loaded, web browsing is also decent.. yeah in pics and videos C510 will be much better.. bt it has some prob too after few months its response becomes very slow..
where C5 has a quite powerful ARM processor.. OP can easily view all PDF,doc,etc/..
this feature wont be dere in SE..
Old 11-12-2010, 12:40 AM   #17 (permalink)
AJJU
azzu's Avatar
i agree with u here
can i know why , i mean on both phone's more apps can be loaded are there any restrictions here?
By using opera mini on both ... no difference , u can use other java browser too if needed,,
i dont know how ur claiming this...i have personally used this mobile and my frnd has been using this mobile from quite a lot time no problems yet..
yes c5 has powerfull processor i agree with u here
, although pdf , doc can be installed on c510 by third party java apps
inspite all this , c510 has excellent cam ,with autofocus , smile detection , Accelerometer sensor ,those beautiful flash themes and menu's etc..
Old 11-12-2010, 11:00 AM   #18 (permalink)
^^ I beg to differ. I haven't found any (free or paid) java app. which can read pdf or office files. If you know any, please let me know. Java cannot simply beat Symbian OS.
The c510 as well as c5 costs well above the OP's budget. Let the OP decide now.
P.S - While looking for sony-erricson, I bumped up on a model Cedar 3g, looks well promising.
Old 11-12-2010, 03:48 PM   #19 (permalink)
nokia c5 is Symbian 60 series mobile. and u also knw either sony has more apps on internet or nokia symbian... nokia is always ahead in dis case..
bt display colors.. will dey it be havin better display clearity as much as C5?
well in SE forum only 2 person were claiming dis issue.. thats its very slow nw after 1month of usage.. phonebook takes many sec to move to one particular letter..
yeah
SE is gr8 in takin pictures and music.. nokia C5 cant provide such quality in dat price..
Old 11-12-2010, 04:51 PM   #20 (permalink)
Swimming, eh??
Guys, my sis aint a geek to be worried about mobile applications.
Can i know the cost of both cellphones.
Old 11-12-2010, 04:59 PM   #21 (permalink)
c5 - 7.5k
c510 - arnd 8.5
Old 11-12-2010, 07:01 PM   #22 (permalink)
AJJU
azzu's Avatar
"MobilePDF Reader".. it can be installed on java mobile..
while about the hanging thing ... there are many issues even with nokia c5. claimed on the Nokia Forum's ( no mobile is Perfect).
BTW : NOkia c5 : 7.2k
SE c510 : 7.5k
as OP said no need of Heavy app installations ..
c510 is great ( for the given requirements of OP) coz of excellent UI , CAM , Solid build ...as OP's requirements are..
Old 11-12-2010, 08:19 PM   #23 (permalink)
^^ I have tried the "Mobile PDF" on several phones & it fails to work on all of them. This is due to memory limitations of low-end phones. And what about Office ??
The OP in his first post asked for a phone which supports many apps. In the above post, he is saying the opposite. I request the OP to clarify his exact requirements as well as the max. budget.
Old 11-12-2010, 09:50 PM   #24 (permalink)
Swimming, eh??
And even with that, the 'application' word was brought into use cause quite frankly I thought we were speaking of pre loaded apps.
Btw, why the heck are we argueing for pdf reader.
I am pretty sure the most important applications will very less clicked on, let alone a pdf reader.
Anyways, so should i shortlist these two phones or are there any other models worth mentioning.
Old 11-12-2010, 10:39 PM   #25 (permalink)
^^ I apologize for arguing over pdf. I just want to press my point that there is no reason to buy a Java-based phone which costs over 5k.
I again ask you to clarify your budget. The phones mentioned are well above the budget in your first post.
Old 11-12-2010, 10:50 PM   #26 (permalink)
AJJU
azzu's Avatar
Toad , yes finalize both fones and check both phones live,,,
go for watever u like
Offtopic aul u said u didnt find any apps of pdf reader for java mobiles and now ur saying u tried it ,,, ???
it worked well in my case..
i agree with u on office , but its not the requirement here i guess..
Old 12-12-2010, 12:15 AM   #27 (permalink)
^^ It is my mistake that I didn't already wrote in brackets (except mobile pdf). I knew you would suggest that because there is no other software for pdf.
Old 12-12-2010, 12:35 AM   #28 (permalink)
Swimming, eh??
@ pauldmps, azzu, hey thanks a lot fellas.
I'l check both of em and let you when i get one.
Thanks again.
Old 12-12-2010, 08:59 AM   #29 (permalink)
AJJU
azzu's Avatar
^ No problem...
plz surely let us know which u selected
