Old 24-11-2010, 02:23 PM   #1 (permalink)
sts
Thumbs up Best smartphones under Rs 20,000
Hi,
I am planning to buy a new smart phone for myself. But unfortunately as there are lots in the market, Im a bit confused with which I should go for. If I like the mobile, its price might be high, or if the price is in my range, it might not have enough features. I am mainly interested in Sony Ericsson, Samsung, and HTC brands. Else anyone can suggest any other better brands.
The main features I am interested in are:
1) Camera- 3.2MP or more
2) Blutooth
3) Amoled screen
4) WiFi
5) TV-out port
6) Capacitive screen
7) GPS
8) Very good sound quality
9) Price- below 20k
Please advise....
sts is offline   Reply With Quote
Old 24-11-2010, 03:48 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Best smartphones under Rs 20,000
hmm. I think you will get better deals if you increase the budget a bit and there is lot of difference between sub-20k and above phones.
1. Nokia N8: 22k
2. HTC Legend: 23k
3. N900: 24k
4. Milestone: 21k
5. Samsung Galaxy S: 26k
6. HTC Desire: 27k
7. SE Xperia X10: 25k-26k
desiibond is offline   Reply With Quote
Old 24-11-2010, 05:49 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by desiibond View Post
1. Nokia N8: 22k
from where u got this price???
@sts: go for samsung wave
Old 24-11-2010, 05:57 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
not the right price? someone on twitter said that it is retailing for some 22k.
Old 24-11-2010, 06:16 PM   #5 (permalink)
Believe Me or Not!!!
Nokia c7 meets all of your requirements.
But it seems like both c7 and n8 are facing some software issues ...
Better go for motorola milestone...
NainO is offline   Reply With Quote
Old 24-11-2010, 06:17 PM   #6 (permalink)
Get Samsung Wave S8500. It meets all of your requirements:
1) Camera- 5MP with LED Flash (Can record 720p videos)
2) Bluetooth - 3.0 with A2DP
3) Screen - Super AMOLED touchscreen (capacitive, 2M colors, )
4) WiFi - Yes
5) TV-out port - Yes (according to gsmarena.com, check before buying)
6) Capacitive screen - Yes
7) GPS - Yes
8) Very good sound quality - Good according to the reviews.
9) Price- About 17k (according to fonearena.com, check with your dealer)
The OS is Samsung BADA which supports true multitasking. The number of apps available for the OS has increased much, so it won't be a problem either.
Official Phonearena Review:http://www.phonearena.com/reviews/Sa...-Review_id2452
Official GSMarena Review: http://www.gsmarena.com/samsung_s850...review-480.php
Fonearena (Indian site) Specs: http://www.fonearena.com/samsung-s8500-wave_1128.html
pauldmps is offline   Reply With Quote
Old 24-11-2010, 06:29 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
C7 is kind of overpriced and yes, it's better to wait and see than to jump the S^3 ship right now. If the budget is 20k, Milestone would be the best bet (like NainO said).
@pauldmps, If I am right, Samsung has pulled Wave out of the market to make way for new wave phones and Galaxy phones.
Old 24-11-2010, 06:36 PM   #8 (permalink)
Still it might be available. If not, Wave II is just round the corner.
P.S. : I would not buy a Nokia Symbian device - They are overpriced & the OS is getting poor reviews everywhere.
EDIT:
Wave is available at some online stores so it should be available in the market too.
Old 24-11-2010, 07:22 PM   #9 (permalink)
Yes, WAVE has TV Out but sadly no cable to fulfill that purpose.
Sound quality is decent/good(for phone with one speaker) but not very good(as of phones with two speakers hav).
I myself own a WAVE, its 2-3 months old and cost me around 17.5k
Yes wave is a great device but gonna be extinct from market as samsung has launches wave 2(didnt liked it though)...
But milestone has 3.7 inches screen, full qwerty keypad, android and great built quality...
You cannot go wrong with both of these mobile phones...
Old 24-11-2010, 09:55 PM   #10 (permalink)
elton_1991's Avatar
Dude,use nokia 5800 tv cable,u can get it at any nokia store or good mobile store..it works perfectly for me..
Oh and +1 to buying the wave
elton_1991 is offline   Reply With Quote
Old 26-11-2010, 09:38 PM   #11 (permalink)
^^^me too.
Using TV Out cable provided with my previous Nokia N82. And it works fine too...
But it wud hav been better if it was bundled with wave too...
