Old 14-11-2010, 09:39 PM   #1 (permalink)
Question Need Mobile phone with touchscreen & slide-out qwerty keypad
Dear All,
I am looking for a mobile phone that has both touchscreen & slide-out qwerty keypad...one example being Nokia C6. My budget is 20k. Any good company will do. Plz suggest me some.
Thanks in advance,
Troy.
onlytanmoy is offline   Reply With Quote
Old 14-11-2010, 10:28 PM   #2 (permalink)
Believe Me or Not!!!
Default Re: Need Mobile phone with touchscreen & slide-out qwerty keypad
C6 is not worth it and new C6-01 dont have a qwerty. Nokia only has e7 with qwerty and touchscreen but will be out of budget. So, no nokia phone in this category...
I recommend motorola milestone. Its good handset- fulfill your requirements and hav great features...
Other phone to mention is LG gw620,but its not as impressive as milestone...
NainO is offline   Reply With Quote
Old 14-11-2010, 11:33 PM   #3 (permalink)
^^Isn't Milestone for arnd 24k?If it is its crossin his budget by a huge margin.
ssb1551 is offline   Reply With Quote
Old 14-11-2010, 11:59 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
no. milestone costs 21k now. check these phones:
1. BB Pearl 3G
2. Milestone
3. SE vivaz pro if you are okay with symbian.
desiibond is offline   Reply With Quote
Old 15-11-2010, 07:05 AM   #5 (permalink)
6x6
half way there
6x6's Avatar
^add SE x10 mini pro, if small screen size isnt a issue.
Intel C2D | G31 | 2GB | 320GB
6x6 is offline   Reply With Quote
Old 15-11-2010, 08:51 AM   #6 (permalink)
thanks for the suggestion guys.
one question though- as NainO said
C6 is not worth it..
so, wats the real issue with Nokia C6?
Old 15-11-2010, 09:07 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ugly looking and bulky
old OS
resistive touch
average multimedia
Old 15-11-2010, 10:10 AM   #8 (permalink)
^^..bond went gung-ho on C6!!
Old 15-11-2010, 10:28 AM   #9 (permalink)
C6 is just an average phone - neither good in multimedia nor good looking.
When you are willing to spend 20k, then this phone is not worth it.
Old 15-11-2010, 12:32 PM   #10 (permalink)
i got my answer..thanks again guys
Old 15-11-2010, 05:46 PM   #11 (permalink)
Living to Succeed
ajayashish's Avatar
i am using Omnia Pro B7610... u can try that...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline   Reply With Quote
Old 15-11-2010, 05:57 PM   #12 (permalink)
I think Omnia Pro dont hav touchscreen...
Am i right???
Old 15-11-2010, 06:13 PM   #13 (permalink)
Living to Succeed
ajayashish's Avatar
Nope it is complete touch screen with sliding keyboard
Old 16-11-2010, 07:45 AM   #14 (permalink)
thanks mate for suggesting this phone from Samsung.
