Old 22-10-2010, 08:42 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Tech Freak Digitian.
TSPatange_1309's Avatar
Exclamation Secret Mobile Spying_the Detective trick!!!
Now you can spy on anyone using your cellphone. Just do the following.
-Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"
-Short-circuit the left middle and right pins on the bottom of the mobile phone with all connections touching each other this will activate profile "Headset".
If you cant do this just keep your earphone connected to mobile.
-Now place it under a table in a room and call it. Now you can use your phone for checking out what people are talking about in a room. Just call on your phone.
-The phone receives the call without ringing and you can listen to what people are saying.
NOTE- USE AT YOUR OWN RISK..!!!
_________________________________________________
TSPatange_1309 is offline   Reply With Quote
Old 24-10-2010, 12:59 AM   #2 (permalink)
Dev
dreatica's Avatar
Default Re: Secret Mobile Spying_the Detective trick!!!
Is this guy spamming digit or promoting digit ? check his twitter...so funny to see this !!
dreatica is offline   Reply With Quote
Old 24-10-2010, 11:40 PM   #3 (permalink)
kindoff ! in one way he is teaching all the tricks or something in the forum and he is promoting , anyways since mods have not interfered here, he can continue ! good luck with the tricks
tejaslok is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/133209-secret-mobile-spying_the-detective-trick.html
Tanmay Patange (TSPatange_1309) on Twitter This thread Refback 23-10-2010 04:35 PM
