View Poll Results: Best Mobile brand-
Nokia 1 20.00%
Samsung 3 60.00%
LG 0 0%
Sony Erricson 2 40.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 17-10-2010, 05:06 PM   #1 (permalink)
Tech Freak Digitian.
TSPatange_1309's Avatar
Thumbs up Developer codes for SAMSUNG mobiles.
I have found some mobile tricks for samsung mobiles. Actually these are the tricks and entertainment for us but it has been created for mobile developing and for adding some new features specially created by developers.
Actually these are codes from developers of a mobile software systems.
Following are some developer codes for samsung mobiles. It strictly warning to you, that i really dont know how it will affect your samsung mobile. So beware at use at your own risk-
On the main screen type *#06#
Information you get from the IMEI (International Mobile Equipment Identity)
XXXXXX XX XXXXXX X
TAC FAC SNR SP
TAC = Type approval code of your samsung Mobile
FAC = Final assembly code of your cellphone
SNR = Serial number of your samsung Phone
SP = Spare
If you have downloaded corrupted or incompatible Java midlets or other media,
which are causing problems with the phone, try this
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
The master reset code is:
#*7728#
This will not delete anything from your
mobile phone, but set each and eveything to its
default/standard setting as it was on the time of purchase.
To unlock your phone put a sim from another company,
now type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks.
This code may not work on the older phones and some of the newer phones.
If it doesn't work you will have to reset your phone without a sim in it
by typing *#2767*2878# or *#9998*3855# (not tested)
Other Samsung Codes
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
Note- Use at your own Risk.
TSPatange_1309 is offline   Reply With Quote
Old 18-10-2010, 09:08 PM   #2 (permalink)
Default Re: Developer codes for SAMSUNG mobiles.
awesome .. great pice of help...
Is there any code by which we can use our samsung flash like TORCH ....???
how do u track a SIFIR :-)
chetan.g is offline   Reply With Quote
