Old 02-10-2010, 02:49 PM   #1 (permalink)
Exclamation Fully loaded phone under 8k
hi guys,
my e71's keypad has gone a bit awry so am deciding to exchange it for a new phone under a budget of 8k (maximum including concession by exchanging the e71). please suggest a full feature packed phone(stylish, preferably captive touch screen, WI-FI must be there, an ebook reader-optional it must be rugged and it should be java enabled).
Thanks a lot in advance
pranav.seth is offline   Reply With Quote
Old 02-10-2010, 02:53 PM   #2 (permalink)
Default Re: Fully loaded phone under 8k
and yes if possible, plz recommend me a android based phone thanx
Old 02-10-2010, 03:37 PM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
at that price get Samsung i5500 Galaxy 5
Although it have a poor screen but its loaded with all features
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 02-10-2010, 06:34 PM   #4 (permalink)
guys plz reply (i m a multimedia buff so plz a good screen!!!!)
Old 02-10-2010, 08:56 PM   #5 (permalink)
Addicted
Sorry no good android phone at that budget. If possible get Samsung Galaxy 3 which is 4k over budget.
the_souvik is offline   Reply With Quote
Old 02-10-2010, 11:47 PM   #6 (permalink)
New Gen Guru
sujoyp's Avatar
but remember samsung galaxy 3 also have poor resolution screen...soo its not for u
u can have SE X8 when it get 2.1 for 13k
or else get nokia 5230 which have good resolution screen but no wifi for 7-8k
Photography Gears -
Old 03-10-2010, 01:58 AM   #7 (permalink)
v4u_luv2004's Avatar
Dude get yourself the new Zeus by Videocon which is fully loaded with power packed features.. 5MP Cam, 3G, Wifi, Bluetooth, A-GPS and last but not the least its an Android[600 Mhz proc] phone and comes with v1.6 upgradeable to 2.1 Eclair...
Oh yeah its available at the price tag of Rs 10999
n forgot videocon is throwing away an 8GB card free with it too..
Check the offer by FlipKart
Videocon Zeus Evolve V7500 Price in India | Flipkart Mobiles
You can even have a look at Acer beTouch E110 which is an Android phone and available @ Rs 8500
v4u_luv2004 is offline   Reply With Quote
Old 03-10-2010, 05:53 AM   #8 (permalink)
plz tell other non-android phone with the above features
Old 03-10-2010, 11:04 AM   #9 (permalink)
New Gen Guru
sujoyp's Avatar
only the other phone with capacitive screen in ur budget is Samsung Monte
But again its resolution is not good enough...
either drop capacitive screen or higher resolution...u wont get both under 10k
Photography Gears -
Old 03-10-2010, 12:43 PM   #10 (permalink)
@v4u_luv2004, one should remember mobile is good. but will Videocon provide timely update for the Android as it is released? cause i heard numerous cases of SE not receiving any official update. so if Videocon takes same route, the 11k price tag may have very less appeal for the demanding crowd.
Old 03-10-2010, 06:57 PM   #11 (permalink)
Addicted
Absolutely agreed sam.shab. Indian companies selling Chinese android are not trustworthy. Galaxy 3's screen is very passable. Non android phone should be 5230.I am a owner of it and assure you except sound you wont be disappointed.
Old 04-10-2010, 02:17 AM   #12 (permalink)
well obviously Videocon as a mobile brand is total nonsense cos at the end of d day they r one more chinese brand in d list of never ending mobile brand segment... but still m happy that atleast they r takin sum initiative to b different by introducin such fones as Zeus.. N wen it comes to Android fones none can beat HTC & Samsung...
He shud increase his budget to get a gud android fone...
My pick is Samsung Spicia and HTC Wildfire and both available under 15k
Old 04-10-2010, 07:02 PM   #13 (permalink)
Addicted
5230 hands down buddy.Buy it now as stokes r running out.
Old 05-10-2010, 03:28 PM   #14 (permalink)
Originally Posted by irvinelmo View Post
Hi,
I'm looking to buy phone under 8K,with the following features:3G,GPS navigation.Which phone would u recommend( I don't want a camera phone)??Thanks
Well buddy i would say go ahead and buy a Nokia C5(Rs7.5k) for urself..
Its a gem.. Got 3g, GPS and also its a s60 device with a 600 MHz processor...
Then thrs Nokia 5230 or 5235 also to look for...
Old 05-10-2010, 09:15 PM   #15 (permalink)
guys plz help me one more time ....can i get all the features without capacitive touch screen?
Old 07-10-2010, 05:23 PM   #16 (permalink)
plz guys help me
Old 07-10-2010, 06:56 PM   #17 (permalink)
Addicted
No phones other than above mentioned does not fit your budget. Wait for some time as new models are coming and with decreased prices.
Old 07-10-2010, 06:57 PM   #18 (permalink)
Addicted
Old 07-10-2010, 07:02 PM   #19 (permalink)
New Gen Guru
sujoyp's Avatar
look bro I will make it simple
1.U want an android with capacitive screen then Samsung Galaxy 5 but it have poor screen & it have wifi
2. No other android phone worthwile/available under 10k
3. If u can adjust with hi-res Resistive screen then Nokia 5235 is good enough at that price but none of Nokia 5230,5235 or 5233 have WIFI only 3g
I recommend Galaxy 5
Photography Gears -
Old 09-10-2010, 09:24 PM   #20 (permalink)
i don't want android and capcitive touch screen as it will not fit in my budget. Then wat are the options that i am asking!
Old 09-10-2010, 11:52 PM   #21 (permalink)
New Gen Guru
sujoyp's Avatar
bro u have to drop wifi too
or u have to get 5800 with high resolution screen+wifi+symbian
Photography Gears -
Old 11-10-2010, 11:19 AM   #22 (permalink)
rahul_c's Avatar
Check out Spice Mi-300 it's gud and meet all your requirements
rahul_c is online now   Reply With Quote
Old 11-10-2010, 06:09 PM   #23 (permalink)
Addicted
sorry rahul don't even say that.No one should want a Chinese phone (yes it is a Chinese phone ) which would be a **** after a year.
Old 14-10-2010, 10:17 AM   #24 (permalink)
@pranav - Its simple buddy!With ur budget of 8k u can't hv ur cake n eat it too!!Within 8k the best multimedia phone u can get is Nokia 5230/5235 coz these hv damn good resolution of 360x640,so when u watch videos on these phones the experience is amazing!!Of course u gotta bargain for sound quality but that shouldn't be a prob if u get in ear-phones of Sennheisser or Creative!!
ssb1551 is offline   Reply With Quote
Old 14-10-2010, 12:31 PM   #25 (permalink)
go for nokia c 5 it is very good phone in ur budget aprox 6k
gaurav_rocks is offline   Reply With Quote
Old 18-10-2010, 03:49 PM   #26 (permalink)
Well buddy certainly Nokia C5 is a superb phone and has got a very powerful processor but the price is not 6k its 7.5k.. The only feature it lags is a WiFi other than that its a gr8 fone.
