16-09-2010, 06:15 PM
Cannot choose between Samsung Champ & Nokia C2-00
I am currently using Nokia 3110c & looking for a replacement.
I am totally confused between Samsung C3300K Champ & Nokia C2-00. While both belong to different genres of mobile phones, the dual-sim functionality on Nokia & touchscreen at such a price on Samsung - both are tempting.
Could you guys suggest the best out of these two (Please don't suggest any other phone)?
Is Samsung good enough to consider? Is it as easy as Nokia to be connected to a PC using PC suite? Is the user interface comparable (if not better) than Nokia s40 phones?
I have no problems with the Nokia battery even after 1-year of usage. Can I expect such battery performance with Samsung in the long run?
Also, can Java apps not specifically designed for touchscreen phones work with touchscreen phones?
Thank you for reading such a long post & so many questions. Any help is appreciated.
17-09-2010, 09:01 AM
Re: Cannot choose between Samsung Champ & Nokia C2-00
Do i need to get gps service activated from vodafone. Before i use it on phone?
17-09-2010, 09:30 AM
Uhu, Not Gonna Happen!
Champ has a better UI with nearly all the features C2 has. But it is too small to be used as touchscreen phone. Moreover it is resistive touch, after some time you could feel irritated because of such less space to fit your fingers into. That is the only negative point I could say about this phone.
But C2 is not a "champ" either. There is no video recording. Although FM,Audio Player, Video Player, Java, Bluetooth, Camera and Email are the features worth mentioning.
I am not a big fan of touchscreen phones, so there may be disparity among my perceptions with others here. In the end choose what you like most.
My personal blog - http://gagan.scholarguru.com
17-09-2010, 01:27 PM
Thanks for replying. But my original questions are not answered.
The most important thing about which I am concerned is battery life. Is Samsung battery reliable?
17-09-2010, 01:35 PM
New Gen Guru
I am impressed by the Champs performance and features...and according to reviews it gives a good battery life...they claim it 12hrs talk time
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
17-09-2010, 02:29 PM
Oops sorry. I failed to mention that Champ is better one among these two. As sujoy said, 12 hrs talktime is really impressive thing
17-09-2010, 06:07 PM
12 hrs talktime when brand new. What will happen after one year or so ? Will it give the same performance?
I once bought an LG phone. Its battery died in about 10 months. That is why I'm unsure about buying phones other than Nokia.
Any Samsung users there?
17-09-2010, 08:30 PM
you were unlucky mate. LG and Samsung make good phone these days IMO.
19-09-2010, 06:35 PM
I bought a Champ a week back and its just wonderful. The onscreen keyboard is a bit tricky to use but once you are used to it, evrythng looks magical. The photo/video resolution is real bad. And they do not bundle the data cable or the PC suite (you can download it from the Samsung site). You can install java apps. Does not support 3G but the GPRS/EDGE speed is really good. At just 4k, the Champ is a real good buy.
19-09-2010, 07:03 PM
A Really satisfying reply. Thank You. I'm looking forward to buy this phone soon.
20-09-2010, 10:10 PM
 Do post a review when u have bought one.
20-09-2010, 10:28 PM
^^ Yes! sure.
28-09-2010, 10:37 AM
I recently bought Samsung Champ, Its really impressive, although the VGA cam is not good, as many phones are able to deliver 2.0 MP cam for very low cost.. The touch is very awesome. I loved this phone.. the batery life is really great, I used almost 8 hrs of music playback and still the battery shows 3/5 bars.
I have a small issue, I can't able to install more Applications or Games. I have to delete some games to install other. And the file size will not exceed 450KB. Any one having some answers pls respond. And I cannot able to get Samsung Apps for this mobile as it is not at all detecting.
02-10-2010, 07:07 PM
TopTrix
i have a samsung champ.
its really a good phone at such price. the touch screen is also best at this price. it has a calibration for touch sensitivity so u can adjust.
THE ONLY PROBLEM IS though it has JAVA support, u cant install any java application. i dont know why but when i tried to install OPERA mini via WAP downloading & also many other apps, it showed error.
all other features are good.
02-10-2010, 11:38 PM
New Gen Guru
^^ there must be some trick to install java software...I remember a similar problem with samsung star...it have been solved
Photography Gears -
03-10-2010, 12:38 PM
GSM arena review says Opera mini can be installed. though the model is slightly different (as it have 1.3Mp camera).
03-10-2010, 03:30 PM
You can trust a samsung battery. I am using a samsung x200 since 2006 and even now i am getting a standby backup upto three days...
And most popular nokia phone has a battery made by samsung. Phones like Nokia N900 nokia 1100/1108 are using samsung battery.... just peel the battery cover of a nokia phones to know, what make it is?.
