Old 25-07-2005, 12:56 PM   #1 (permalink)
Default How to send MMS
hey friend i just want to know how to send mms and whats is the rate of sending it.[/b]
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
Old 25-07-2005, 12:58 PM   #2 (permalink)
many questions
1) which network u r on?
2) do u have GPRS enabled ?
3) Does ur friend have GPRS enabled?
I\'M BACK
khandu is offline
Old 25-07-2005, 01:12 PM   #3 (permalink)
Just Do It
Charley's Avatar
Default Re: How to send MMS
M8, for sending MMS u need GPRS. U have to contact ur provider and ask them to activate it. The rates also differs between many operators, so that also should be confrimed with them.
Charley is offline
Old 25-07-2005, 01:21 PM   #4 (permalink)
I have orange connectio.
but i did not enable GPRS.
may be now i have to enable it.
thanks guys
- Goethe
Old 25-07-2005, 01:23 PM   #5 (permalink)
Just Do It
Charley's Avatar
Ask them for WAP activation also when u do contact them
Charley is offline
Old 28-07-2005, 01:55 PM   #6 (permalink)
I have activated gprs and mms from airtel, but none of the mms can be sent or recieved by me. i live in nagpur..........is it possible for anyone to send me any type of mms.........???????
p_d5010 is offline
Old 28-07-2005, 02:04 PM   #7 (permalink)
Just Do It
Charley's Avatar
Well dude dont just sit there... Shove the customer care a complaint that its faulty and not working ..... Insist them to rectify the prob ..
Charley is offline
Old 20-08-2008, 02:08 PM   #8 (permalink)
rgfetyrtyt
rakee123143 is offline
Old 20-08-2008, 02:23 PM   #9 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Have u saved da settings u recieved after activating mms.?
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 20-08-2008, 06:23 PM   #10 (permalink)
Ask CC to enable MMS(or GPRS if they require you to have it to send GPRS). You will recieve settings after activation, save them and set as default. Now you should be able to send/receive mms.
ThinkFree is offline
Old 20-08-2008, 06:33 PM   #11 (permalink)
Juke Box Hero
kdjfdkjdfjoiuoueqrd,mvc, i can spam too! Closed!
Hitboxx is offline
