Just one small question. What is the cheapest STD mobile plan that I can get (can be CDMA/GSM) I already have a reliance CDMA phone (Re.1/3mins) If I required I can buy two new handsets/ SIMs as well!
I have done some research and found a small solution. I will buy two sims from a provider who gives local to local calls free for the lowest price. I keep one and send the other one to AP after activating free incoming while roaming service. Will this work??
Thanks a ton in advance.
Before I forget, hats off to you guys. I havent seen a more active forum than this one. And you all are so helpful!
P.S.Please dont suggest that I simply use chat/VOIP. Its simple not possible right now. Thanks again.
