Old 25-07-2010, 10:28 PM   #1 (permalink)
sree01's Avatar
Default mobile phone within 9k -13k range
HI guys, please suggest a good mobile phone within 9k and 13k range.I like to have 3g and wifi. Also want good battery and OS.
sree01 is offline   Reply With Quote
Old 26-07-2010, 09:55 AM   #2 (permalink)
Addicted
Default Re: mobile phone within 9k -13k range
In my opinion nokia 5800xm is best suited for u.check it out.it is 13k. at 9k you can not get wifi and 3g.
the_souvik is offline   Reply With Quote
Old 26-07-2010, 09:16 PM   #3 (permalink)
sree01's Avatar
what is your opinion about the following?
Samsung galaxy spica
Samsung corby pro
Samsung Omina lite
nokia c6
Nokia E5
Old 26-07-2010, 11:47 PM   #4 (permalink)
New Gen Guru
sujoyp's Avatar
1.Samsung Galaxy Spica is not available
2.Corby pro is good but is java based...it can be considered
3.Omnia Lite...wm 6.5 is not good enough
4. Nokia c6 will not be released by September
5. E5...dont know much but E series r never good in multimedia
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 27-07-2010, 10:50 AM   #5 (permalink)
sree01's Avatar
thanks sujoyp,
do you know anyone who uses corby pro?
I came across another model samsung monte,Nokia X6,SE hazel and HTC wildfire. what is your opinion about these models?
Old 27-07-2010, 12:10 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Nokia X6 is a decent model and the package is total VFM for 15k-15.5k.
SE Hazel : Similar to X6 but not a touch screen mobile. A good allrounder and good for those who prefer phones with hard keys.
HTC Wildfire: hmm. this one should be around 12k-13k and anything more than that means it's overpriced. The low resolution display and battery life can be deal breaker here.
among the current crop of phones, if you are okay with Symbian, Nokia X6 16Gb makes most sense. I am not sure about C6. It's a new phone, noone really knows how good the firmware is or how good the build quality is. From videos, the build quality looks just okay and to me, it looks ugly when compared to other Nokia phones in that segment.
desiibond is offline   Reply With Quote
Old 27-07-2010, 02:47 PM   #7 (permalink)
New Gen Guru
sujoyp's Avatar
At ur budget
Touchscreen = Nokia x6
Non-touch= SE hazel
Photography Gears -
Old 27-07-2010, 10:00 PM   #8 (permalink)
sree01's Avatar
what is the price of Nokia x6? I thought it is above 15.5k
Also what is the price of HTC Wildfire?
Please give your opinion about SE Aino Classic
Old 12-10-2010, 01:51 PM   #9 (permalink)
neiljhonson01
Posts: n/a
Hi Guy, I want to advise you that you may buy Samsung coreb. Because it is good is a good phone with a reasonable cost. Find out more updates on
samsung mobile phones and Samsung Latest Mobile Phone
Old 19-10-2010, 02:49 PM   #10 (permalink)
In search for Tech Gyan!
Lightbulb Re: mobile phone within 9k -13k range
You might consider the newly released Samsung Galaxy 3 and 5. As of the news that have come out about both these handsets, both are good VFM handsets, and both meet your criteria. i suppose both have Android 2.1 OS. So, I would suggest go in for these ONLY AFTER YOU'VE DONE ALL THE HOMEWORK ABOUT YOUR CHOICE!
You can consider visiting GSMARENA. although the comments of the users/readers is somewhat very confusing, but, I can bet that they have all the specs correct. Samsung India website is useless, as it doesn't provide all the specs.
I'm a KID in this BIG Cyber World!
CyberKID is offline   Reply With Quote
Old 19-10-2010, 03:05 PM   #11 (permalink)
Aditya11's Avatar
I concur. Galaxy 3 is best VFM Android phone as of now. You can read my detailed review of the same here.
Aditya11 is offline   Reply With Quote
Tutorial: Flashing k550i to w610i !! a_k_s_h_a_y Mobiles and Tablets 822 13-10-2010 08:25 AM
plz Suggest me a mobile phone.... rohanz Buying Advice 2 09-06-2010 11:27 PM
required a mobile phone with a longer battery life?? raja2281 Mobiles and Tablets 3 26-02-2010 04:27 PM
Has iPhone Started A Touch Screen Mobile Phone War? Kiran.dks Technology News 7 11-02-2007 12:24 PM
- by soumya
