I saw most of my friends cool laminating their mobile phones.i told them that,there will be a lot of problems regarding lamination.so for you mobees i like to give my caution regarding laminating mobile phones.its my own experience which happened to me and my friends.
the prob's are,
*The phone used to get hot due to the fact that lamination stops any air that goes in.
Also i dont like the keypad feeling when its laminated.
*i had faced signal reception issues as well as voice clarity issues when i got my mobile laminated... have faced this problem for many handsets and i dont recommend mobile lamination. also sometimes after lamination the shopkeeper might damage the mic and ear piece of the phhone if he carelessly makes those holes on top of them ... beware of this !!! and ya its a pain if u have to take out your sim card or battery or mmc card. so in all lamination not recommened by me.
*Also i noticed no of microscratched on the body, specially on the corner due to minute friction between lamination and body due to constant usage on the phone body, invisible to us normally but it becomes visible after you remove the laminate.
Use a good poutch insted( poutch and not cover ).
Also its not suitable for today's smart phones wher eyou need to change the MMC/SD cards.
