Old 28-06-2010, 08:14 PM   #1 (permalink)
Default Nokia N79 charger
My original AC-5N charger that used to give output of 5.0V 800mA is not working anymore. Is it ok if I use AC-3N which gives output at 5.0V 350mA for N79??
Nokia N79
SE K310i
Xbox 360 Elite
P4 2.67 GhZ, 512 MB RAM, 1 TB HDD, Geforce 5200 (VRAM 128 MB), LG 23" Full HD Monitor.
karamvirk is offline   Reply With Quote
Old 01-07-2010, 11:15 PM   #2 (permalink)
Default Re: Nokia N79 charger
not a single reply?? Wsup guys?? I thought this was a very simple query !!
Nokia N79
SE K310i
Xbox 360 Elite
Old 02-07-2010, 10:39 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
50 mA difference won't harm your fone. Charge for an hour and see if the device is getting unusually hot, or getting charged much before time. If its behaving the same as with the old charger, then you can go ahead with it.
Nokia N86 8MP
Lucky_star is offline   Reply With Quote
can apps ..... Sparsh007 Mobiles and Tablets 10 12-11-2006 01:46 PM
- by soumya
