LinkBack (2) Thread Tools Display Modes
Old 14-06-2010, 11:45 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Altec Lansing vs Zebronics - 2.1 - help!
I know its been quite some time and i have still not decided
Although on the previous thread Altec VS4121 was suggested as the best but there were no mention of zebronics, i got confused after reading digit's comparison for speakers in 2009 n 2010.
to my surprise both comparison rated Zebronics speakers better than Altec :O
so now its down to 4 speakers... and digit rate it as:
Zebronics Duality 5000> Zebronics SW2600> Altec VS2621> Altec VS4121
Totally confused!!! has everyone tested Zebronics or altec vs2621???
ankushkool is offline   Reply With Quote
Old 14-06-2010, 11:55 PM   #2 (permalink)
sriharsha_madineni's Avatar
Default Re: Altec Lansing vs Zebronics - 2.1 - help!
Most of the Zebronics speakers sound boxy, I don't understand why do they fare well in Digit's Tests.
I would say go for Altec VS4121
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now   Reply With Quote
Old 15-06-2010, 12:08 AM   #3 (permalink)
ankushkool's Avatar
ya thats what everyone is suggesting... but is VS4121 better than VS2621? then what is de use of the reviews... there has to be some truth in the reviews!!!
Old 15-06-2010, 06:34 AM   #4 (permalink)
Freshly Churned Chutny :)
Debu_013's Avatar
In digit reviews zebronics feature better cuz of the value proposition they are.
Altec speakers are much costlier.
Zebronics Duality 5000 is a good set of speakers.
iBall Raaga is also a good set of speakers, its got full wood body.
+==CPU= AMD Athlon II X2 250 3.0 GHz
+==MB== AMD 690V (MSI K9AGM4)
+==RAM= Transcend 2GB DDR2 800MHz
+==Graphics_Card= XFX GeForce 8600GT 256MB GDDR3
Debu_013 is offline   Reply With Quote
Old 15-06-2010, 06:49 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
never ever ever rely on reviews written in digit magazine. they are clueless and pointless.
zeb speakers being better than AL is no doubt a big joke.
though vs4121 and vs2621 are both good set of speakers, I still prefer VS4121.
desiibond is offline   Reply With Quote
Old 15-06-2010, 10:15 AM   #6 (permalink)
ankushkool's Avatar
Thanks guys... just wanted to be sure i had no idea the comparisons were so unreliable so its still VS4121
Old 15-06-2010, 11:35 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
Sorry to hijack this thread..is 2.0 better or 2.1 better. Which brand you guys suggest. I already have AL 5.1, not satisfied with it.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline   Reply With Quote
Old 15-06-2010, 11:59 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
there are some 2.0's like M-Audio like this:
http://www.m-audio.com/products/en_u...phileAV40.html
These can even beat MX-5021 when it comes to audio quality.
Old 15-06-2010, 02:51 PM   #9 (permalink)
Full range 2.0's are anyday better than 2.1 speaker setup
But they need a good amp to work well.
Klipsch also has some good 2.0 offerings http://www.klipsch.com/na-en/product...-2-0-overview/
BTW which altec 5.1 are you using currently?
Old 15-06-2010, 07:12 PM   #10 (permalink)
ankushkool's Avatar
they must be all high end 2.0 speakers? for entry level i think 2.1 is better? right?
Old 15-06-2010, 11:40 PM   #11 (permalink)
Gracias Senor
dreams's Avatar
Guys, i have a budget constraint. basically looking for VFM, even if it is 1k.
BTW, I own VS3251. This set was a defective one, the sw pin at the rear is faulty, if the plug goes in perfect, bass lacks, if I hover it halfway, it works. Reported to AL, and they asked me to ship it back to them, for which I have to pay. Left it.
Old 16-06-2010, 01:07 AM   #12 (permalink)
ankushkool's Avatar
VS2621 for <2k
VS4121 for <3k
both really good... make ur choice if possible go for 4121 n if on a very tight budget u have no option but 2 go for zebronics which are total VFM!
Old 16-06-2010, 10:23 AM   #13 (permalink)
Gracias Senor
dreams's Avatar
Any specific model number for Zebronics??
Old 16-06-2010, 10:32 AM   #14 (permalink)
ankushkool's Avatar
Zebronics Duality 5000 < 1500
Zebronics SW2600 < 1100
Old 16-06-2010, 12:14 PM   #15 (permalink)
Gracias Senor
dreams's Avatar
Thnx m8..will check for reviews and once finalized had to hunt where I can get it in Chennai.
Old 16-06-2010, 08:16 PM   #16 (permalink)
ankushkool's Avatar
http://www.zebronics.net/contactus.asp
---------- Post added at 08:16 PM ---------- Previous post was at 08:15 PM ----------
if u can extend ur budget to 1.8k go for VS2621
Old 18-06-2010, 10:21 AM   #17 (permalink)
Gracias Senor
dreams's Avatar
thnx m8..will settle for the AL one VS2621
Old 18-06-2010, 05:22 PM   #18 (permalink)
ankushkool's Avatar
actually enquired 2day and found out that VS2621 are available for 1.6K totally worth it
Btw i got VS4121 totally awesome... though i feel that the bass is bit high 4 my room
love it
Old 18-06-2010, 05:44 PM   #19 (permalink)
Gracias Senor
dreams's Avatar
thnx for the small but apt review..will go for it.
Old 23-02-2011, 06:29 PM   #20 (permalink)
ankushkool's Avatar
Just heard a Edifier 2.1 and now dont like mine too much :\
Old 23-02-2011, 06:30 PM   #21 (permalink)
Tech Freak Digitian.
TSPatange_1309's Avatar
Talking Re: Altec Lansing vs Zebronics - 2.1 - help!
@ankushkool What is Dell Studio after your every reply??
TSPatange_1309 is offline   Reply With Quote
Old 23-02-2011, 06:43 PM   #22 (permalink)
ankushkool's Avatar
its in signature... will remove it!
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/128236-altec-lansing-vs-zebronics-2-1-help.html
Thread Altec Lansing vs Zebronics - 2.1 - help! | Digit Forum | BoardReader This thread Refback 10-07-2011 06:23 PM
Raaga - online posts | BoardReader This thread Refback 07-07-2010 10:02 AM
BXR 1221 - Altec Lansing achtung Hardware Q&A 3 26-03-2010 12:42 PM
2.1 speakers required urgent... metalfan Audio 3 24-03-2010 07:56 PM
confused about which Altec lansing to buy... 2.1 or 5.1 hellomotto Hardware Q&A 16 09-05-2006 11:35 PM
Altec Lansing 2.1 ironcross77 Networking 2 24-12-2004 12:37 PM
- by soumya
