Old 29-05-2010, 09:25 AM   #1 (permalink)
pushkaraj's Avatar
Question Need some help in customizing a Dell Studio 15
I am planning to buy a Dell Studio 15. I have the following queries:
1) Is it worth selecting an
Intel® Core™ i5-430M Processor (2.26GHz, 4 Threads, turbo boost up to 2.53GHz, 3M cache)
rather than an
Intel® Core™ i3-350M Processor (2.26Ghz, 4 Threads, 3M cache)
2) If i select
15.6 " 720p WLED (1366x768) Display with TrueLife™
i will still be able to play full HD videos right? Then what is the benefit of opting for
15.6 " Full HD(1080p)WLED (1920 x 1080)Display with TrueLife™
3) Is there a significant increase in battery life if i select the 9-cell battery over? Also, will there be any significant increase in the overall weight of the laptop?
4) I wish to install Linux which means i may need to format and repartition the hard disk. Does Dell provide the windows 7 disc so that i may install the OS again later?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 29-05-2010, 09:49 AM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: Need some help in customizing a Dell Studio 15
basically it all depends on ur budget!
rather than an
@ 2800/- i doubt it...
2) If i select
i think 1366x768 will be enough for a 15" screen, and yes u can watch HD videos on it...
yes there definately is... if u planning 2 use de laptop while travelling... u have 2 get 9cell as dell studio series does not have that great battery life!
if you order it directly 4m there site u should... as i got one, still just confirm with them
wait 4 suggestions 4m some more experienced users...
cheers!
---------- Post added at 09:49 AM ---------- Previous post was at 09:48 AM ----------
yeah! my 500th post
ankushkool is offline
Old 29-05-2010, 10:15 AM   #3 (permalink)
sriharsha_madineni's Avatar
rather than an
2) If i select
I would say go for i5 considering the price diff & turbo boost capability, saves you from upgrading woes later IMO
If you are a movie buff then full HD matters if not then stick to the default one.
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 29-05-2010, 10:27 AM   #4 (permalink)
ankushkool's Avatar
i am not sure but is there much performance diff in i3 and i5?
Old 29-05-2010, 10:54 AM   #5 (permalink)
Hmmm yeah according to the links below, i3 & i5 have the same intel GMA HD graphics solution integrated in both, but it is clocked higher in i5 and also these benchmarks show a considerable difference keeping in mind the 2.8K extra
i5 430
i3 350
benchmarks of both
Old 29-05-2010, 11:46 AM   #6 (permalink)
pushkaraj's Avatar
hey, thanx fr the replies guys. one more question:
is there a difference in performance of 5200 rpm and 7200 rpm drives?
Old 29-05-2010, 11:58 AM   #7 (permalink)
not much for average user
If you are fanatical about performance and gaming, then you might consider 7200rpm
Old 29-05-2010, 12:27 PM   #8 (permalink)
ankushkool's Avatar
again... if it fits ur budget go for 7200rpm
Old 29-05-2010, 12:34 PM   #9 (permalink)
Chetan1991's Avatar
Go for 7200 rpm one. It might produce a bit more heat, but it'll perform better. Since HDDs are the slowest components (excluding ODDs) in a comp, they are a bottleneck. A slow hdd will decrease performance even further.
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline
Old 29-05-2010, 08:53 PM   #10 (permalink)
rags's Avatar
of course ...more RPM means ..faster transfer ...but more heat...thats why now-a-days the manufacturers in their "Green drives" are limiting to 5400 RPM ...
rags is offline
Old 31-05-2010, 06:20 PM   #11 (permalink)
pushkaraj's Avatar
Thumbs up Re: Need some help in customizing a Dell Studio 15
Thanx for your replies every1. Finally i have decided to go for i3 processor, 500GB 7200 rpm hard disk and 9-cell battery
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5533 Yesterday 12:49 PM
Help on DEll INSPIRON and STUDIO.. livebyfaith.anu Hardware Q&A 2 28-05-2010 10:46 AM
Dell Studio 15 Display Inverter and DVD Writer Problem windchimes Hardware Q&A 2 24-05-2010 12:48 AM
How to install XP on Dell Studio? iamall Software Q&A 8 06-04-2010 07:49 PM
Microsoft announces Visual Studio 2008 morpheusv6 Technology News 2 09-06-2007 02:25 PM
- by soumya
