Old 27-05-2010, 07:40 PM   #1 (permalink)
Default incorrect gps position on my phone????
hi guys
i was checking my location on my htc legend with google maps. it shows akola as my position whereas i am in mumbai. y is that? wht cud be wrong?
raja2281 is offline
Old 27-05-2010, 07:46 PM   #2 (permalink)
sriharsha_madineni's Avatar
Default Re: incorrect gps position on my phone????
looks like you might have switched off GPS, so it might be using Wireless networks (A-GPS) for locating your phone and hence incorrect position.
Try it again with GPS Enabled.
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 28-05-2010, 12:07 PM   #3 (permalink)
Gps is on still getting wrong location
raja2281 is offline
Old 28-05-2010, 02:45 PM   #4 (permalink)
R u sure??
I have never heard of defective GPS units on phone, may be you should check with the other legend owners, ask @desiibond he has one.
Old 28-05-2010, 11:50 PM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
no dude.. just update your gps data on phone..
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 28-05-2010, 11:57 PM   #6 (permalink)
@raja2281
Also try this, disable use wireless networks and only Enable GPS and try this time
Old 29-05-2010, 11:32 AM   #7 (permalink)
Originally Posted by sriharsha_madineni View Post
@raja2281
tried it. in location settings i disabled wireless networks and enabled gps satellites. then started google maps then asked for my location, it used gprs connection alongwith gps to determine and after a few seconds location not available temporarily appears. it continues to happen all day. is there any subscription that i need ???
raja2281 is offline
Old 29-05-2010, 11:38 AM   #8 (permalink)
You have to wait until GPS locks into position, what is the status of GPS icon in notification bar, while you get this error! Is it blinking or fixed??
No subscription needed for Google maps, its free it uses GPRS to download map data
Old 29-05-2010, 11:50 AM   #9 (permalink)
the gps icon keeps blinking and then the msg pops up as location not available temporarily. i suppose E icon isnt showing two way signal so gprs might not be active so location is not getting determined.
raja2281 is offline
Old 29-05-2010, 11:56 AM   #10 (permalink)
no,positioning is irrespective of GPRS, gps locks your position, but the application needs network connection to work, otherwise it won't start.
This time wait till the icon stops blinking and gets fixed, then it automatically shows your current position. it seems you are clicking "My position" before GPS is locked. It depends on your current location, it might even take 3-5 mins to lock. So try it now
Alternatively install "compass" app from market to check if GPS module is working correctly.
Old 29-05-2010, 03:24 PM   #11 (permalink)
i inserted a different network sim card and then it showed my location. so i guess some problem with gprs settings of that sim card. thx a lot sriharsha.
raja2281 is offline
Old 29-05-2010, 03:26 PM   #12 (permalink)
Welcome
N86 8MP Phone Memory Full a_to_z123 Mobiles and Tablets 4 14-04-2010 12:37 AM
No Smart phone satisfies me PLEASE help!!!! icekid Mobiles and Tablets 14 09-03-2010 12:15 AM
How to save a wet cell phone dr_jimit Tutorials 13 21-03-2008 07:36 PM
Nokia Tips & Tricks personifiedgenius Mobiles and Tablets 6 16-05-2007 08:28 AM
FOR SELL SONY ERICSSON W800i MOBILE PHONE AT JUST $130usd johnson1 Technology News 2 28-07-2006 02:10 AM
- by soumya
