offline mgmaps/trekbuddy maps for kolkata
can someone create a detailed offline map of kolkata and its suburbs (including saltlake ,rajarhat budgebudge and behala for use with trekbuddy and mgmaps from thsi site http://gm2tb.awokenmind.de/ ,it is the offline map creator for trekbuddy,once you are done with placing all the waypoints and making a clear zone,go to preview map and wait for it and then click on the tab create trekbuddy maps.this will create maps for using with trekbuddy with gps.apart from dat pne may also click the download map option to generate a map for using with mgmaps.I tried this myself many a times just only to fail miserably as only a part is showing up and not the full map.please help
Nokia X6
Nokia E5
Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it)
a 500 GB (priceless,every bits of it) music repo.
Gold Flake,OMR
