Old 11-05-2010, 02:51 PM   #1 (permalink)
Default Need a phone for text messages
Guys, I need a phone only for text messages and dual SIM...please suggest me from your experiences which one will be the best to use for text messaging feature and dual SIM....no other features needed like mp3 ringtones,camera,3g gprs etc...I only need a phone which has nice keypad and easy to type text messages except Sony and Samsung coz there keypad are not user friendly ...Please help me out..
neerajvohra is offline
Old 11-05-2010, 03:39 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Need a phone for text messages
If you wanna only send SMSes, and can avoid dual sim consider Nokia 1203. It has an AMAZINGLY COMFORTABLE keypad for texting. If you are buying 2 sims only for texting, then instead get STel or Reliance's 500 sms/day pack. Reliance pricing is Re.1/day and STel is even cheaper. 500/day local/national is enough for most ppl.
Otherwise, take a look at some of the cheaper Spice phones. There is one which is QWERTY keypad type and costs around 2.4k. Forgot model no so pls google around. It is a dual sim. If you are into qwerty phones give this a serious look.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 11-05-2010, 04:02 PM   #3 (permalink)
Thank you gautham for the prompt reply..I have checked the 1203 model as u suggested..Can u tell me how many messages it can store as I am unable to find this information.. I am using Idea SMS pack which gives me 1000 messages/day..So messaging pack wont be a problem...I am looking for a dual SIM as I never tried it though
Currently, I am using Nokia 5800XM and touchscreen phones are not good enough for SMSes...
Is this the Spice model you are talking about :
http://www.priceindia.in/mobile-phon...4-price-india/
What do u suggest ?? Is it easy to type messages @QWERTY as I never tried the QWERTY stuff...Should I go for qwerty phone or 1203 ?? Any final reviews please ?
Old 11-05-2010, 08:12 PM   #4 (permalink)
The Smaller Bang
Storage won't be much just 60 on phone but you need to delete regularly.
But for a phone with a really comfy large keypad like 1202 and 1203, priced at Rs. 1050, its really worth it.
Check out Nokia 1661 (has additional option of hands free and radio) @ Rs. 1350 which has 250 sms storage if you need higher capacity.
Or Nokia 2323 which has 10mb space for sms'es which is quite large (loads of saved messages). But phone is 2.3k not worth it at all if you only need a SMS'ing machine.
If you wanted to save sms'es all you would need to do is to forward them to the 5800xm phone anyway
So I suggest Nokia 1202 or 1203. Diff b/w them is the keypad goes inwards in 1202 and bulges outwards in 1203. Try both since which to prefer is completely subjective and finger dependent.
Either phone (a "basic phone") has way more comfortable keypad than most other nokia phones I have used to be honest. Big and comfy even for fat fingers like mine. Similar league as Nokia 3110c or 3500c.
Dual sim without reason is pointless.
Yeah its the same spice phone. But qwerty is extremely subjective. Many swear by it (ask QwertyManiac of our forum) others are really uncomfortable with it since it takes a lot of time getting used to. I prefer using T9 dictionary always for messaging since its damn fast.
Old 11-05-2010, 08:40 PM   #5 (permalink)
AJJU
azzu's Avatar
Micromax Q5 excellent sms phone (but has all other Mutimedia features too)
or also have a look at olive's Messenger fones there great for SMS'ing
I love and Live to Design
azzu is offline
Old 11-05-2010, 10:49 PM   #6 (permalink)
Thank you so much for explaining so well...
You got my point as I too have fat fingers
Great Idea
Also, it wont be easy to carry 5800xm and a qwerty phone..So, I am going to mobile store tomorrow and will choose either 1202 or 1203...I think qwerty is not for me
Thanks again for helping me out !!
Old 14-05-2010, 03:15 AM   #7 (permalink)
bought 1203 for myself and spice qt44 for girlfriend..as we both are text savvy and using 5800xm...lol the best part @MetalheadGautham my gf doesnt like the qwerty and its cheaply build...but im loving my nokia
Old 14-05-2010, 09:54 AM   #8 (permalink)
New Gen Guru
sujoyp's Avatar
hey u mean ur nokia types faster and easier then spice qt44...how?? is the spice keys too hard...or there is too much lag?
kindly tell me
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline
Old 14-05-2010, 12:10 PM   #9 (permalink)
spice keys are very hard and they build quality is very low..offcourse spice is java os phone...so it will lag a bit
Old 14-05-2010, 12:15 PM   #10 (permalink)
CA50's Avatar
try LG Gxxx (forgot the exact model no ), its good for messaging. The keypad is quite large and the main thing is that is very cheap only 1150/-
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Samsung D500 Review hbk88in Mobiles and Tablets 28 02-06-2008 10:00 AM
Gsma 2008!!!! dreamcatcher Mobiles and Tablets 26 12-02-2008 10:40 PM
Nokia Tips & Tricks personifiedgenius Mobiles and Tablets 6 16-05-2007 08:28 AM
Symbian Tricks And Tips khin007 Mobiles and Tablets 10 20-01-2006 06:38 PM
- by c4u
