Old 05-05-2010, 01:39 PM   #1 (permalink)
hluachawngthu's Avatar
Exclamation Is reset phone mandatory after up-dated?
I am using Nokia 5800XM and I do up-dated from firmware version v40 to v50.0.005 recently. Is resetting of phone mandatory after updating firmware?
hluachawngthu is offline
Old 05-05-2010, 01:54 PM   #2 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Re: Is reset phone mandatory after up-dated?
jus restart
gopi_vbboy is online now
Old 05-05-2010, 02:46 PM   #3 (permalink)
Reset means reset to phone settings??
If yes, then no
Just Restart the Phone
Aspire is offline
Old 06-05-2010, 10:43 PM   #4 (permalink)
Exclamation Re: Is reset phone mandatory after up-dated?
If yes, then no
Actually I mean "resetting" by pressing some code or making the phone back to the factory settings.
Old 20-05-2010, 09:10 PM   #5 (permalink)
^Check my post
If yes, then no
So you dont need to reset the phone
Aspire is offline
Old 22-05-2010, 03:28 AM   #6 (permalink)
If you have hacked your phone..then don't reset it with
*#7370# as you will lost your hack stuff and other stuff in phone memory.
If your phone is not hacked, its recommended to reset it with the code mentioned above , but backup your contacts and messages, as the phone memory will be empty.
PS: I prefer hard reset after updating 5800xm .
neerajvohra is offline
Virus attack on java phone! ANURAG SHARMA Mobiles and Tablets 3 09-02-2010 10:32 PM
How to save a wet cell phone dr_jimit Tutorials 13 21-03-2008 07:36 PM
Symbian Tricks And Tips khin007 Mobiles and Tablets 10 20-01-2006 06:38 PM
Sony Ericsson W550i Walkman Review hbk88in Mobiles and Tablets 11 30-12-2005 05:53 PM
And here's the prize winning review of the k500!! hbk88in Software Q&A 1 20-12-2005 02:04 PM
- by c4u
