Old 27-03-2010, 02:25 PM   #1 (permalink)
GeekyBoy's Avatar
Default Accidentally corrupted simlock 3110c
I have a problem here guys. I have a one and a half year old 3110 classic which was accidentally simlocked(maybe its corrupted)(its a long story..) and when i press the power button, it does switch on and takes me to the standby screen(which shows "No sim card inserted", obviously). But if i listen to music or play games, it automatically turns off after about 3 mins!! Ive tried all sim unlocking software, etc, but to no avail.
Now I'm thinking of exchanging it with a new cellphone. Could you guys help me on how to exchange it without the store salesman suspecting anything? Thanks!
Btw if there are other workarounds available(like software to revive the phone) than just exchanging the phone do tell me.
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 27-03-2010, 03:43 PM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: Accidentally corrupted simlock 3110c
^ did you try to update the Software of the phone , If not
go to nearest Nokia care the'll do it for around rs 250 /- (may be less ) if it doesnt work
then i suspect there may be a Hardware problem
I love and Live to Design
azzu is offline
Old 28-03-2010, 10:58 PM   #3 (permalink)
GeekyBoy's Avatar
Ive tried software update about 10 times.....no effect. By the way software updates do not change the simlock code by any way........so please any suggestions guys......help me!!!!!! Any way I can get past the store salesman???? I hope its not illegal to ask such stuff here!
GeekyBoy is offline
Old 29-03-2010, 08:13 AM   #4 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
if you have the bill then u can always ask nokia care . but best would be to go to mobile repairing shops and ask them .
Tamoghno is offline
Old 29-03-2010, 08:29 AM   #5 (permalink)
Jai Suresh
lywyre's Avatar
Call your mobile service provider's support and request for the SIM lock no. They will ask your name, your mobile no. etc and also the number on the SIM card. If the details you give are genuine, they will give you the no. for SIM lock and you can unlock it. And for the restarting issue, it is prevalent with 3110. Guess there is no reprieve.
lywyre is offline
unable to install any file....says file corrupted (nokia 5800xm) ajooba215 Mobiles and Tablets 0 26-02-2010 08:09 PM
Pen drive corrupted ! any resolutions ? sankaranand Hardware Q&A 10 01-01-2008 10:29 PM
Recovering from a corrupted regisry which is stopping windows xp to start piyushp_20 Tutorials 2 14-07-2007 01:40 PM
System.ini corrupted - windows xp not loading SGS_001 Software Q&A 14 24-02-2007 07:23 PM
Do not download large corrupted files again, Fix them with rajas700 Tutorials 19 09-07-2006 11:19 PM
- by c4u
