Old 10-07-2005, 02:36 AM   #1 (permalink)
Default How to store mp3 songs in a mobile with good quality ?
hi all..
I need help for Sony Erricson- K750i..
I want to store mp3 songs in my cell. I have heard that one can compress the song ( from 5 MB to as little as 5 KB in size )
I have tried with DBPoweramp.. A hindi song of 5 MB can be made of less size..with decreasing Kbps.. any other good software or
tricks ??
Can anyone tell me how to do it ? Do let me know software which is required for it. ( Freeware / Shareware )
Song should give good clarity when listening using headphone or phone speaker.
Any help ???
PraKs is offline
Old 10-07-2005, 09:34 AM   #2 (permalink)
5Mb to 5Kb. I think you mean Mp3 to MIDI. It's ok if you're making ringtones. They may end up at about 30Kb. Is 750i an Symbian phone? No, I don't think it's a smartphone. If it is, try Ogg format for music. Search for a similar topic (mp3 on 6600) on this forum.
-Keith
Keith Sebastian is offline
Old 10-07-2005, 02:46 PM   #3 (permalink)
K750i is not Symbian phone.
even if mp3 can be compressed from 5 MB to 1 MB itz fine for me..
Do tell me which software can do the job..
PraKs is offline
Old 10-07-2005, 04:43 PM   #4 (permalink)
the best software available is dbpoweramp which ithink u've tried. try setting the quality to 60kbps and see. well asurphoneis not a symbian one, ogg player wont play in it.
hi guyz look at the spidey
spidey is offline
Old 10-07-2005, 06:33 PM   #5 (permalink)
To re-encode to lower bitrate MP3 use CDex (free). See which bitrate works best for you (quality vs filesize). It's personal. Also depends on quality of earphones. The lower the quality of hardware, the lower the bitrate you can use as it's not possible to distinguish loss of audio fidelity.
-Keith
Old 11-07-2005, 10:42 AM   #6 (permalink)
vishal_bhatia87
Posts: n/a
Use iTunes with the settings mention below.
Audio Bitrate: 80 kbps
Channel: Mono
Sample rate: 24.000 kHz
Old 11-07-2005, 11:22 AM   #7 (permalink)
gxsaurav
Posts: n/a
K750i is not a symbian phone for first
Insted of iTunes I prefer that U use Quicktime 6.52 pro, to convert an mp3 file first to un compressed wave, then recompress export to "Sound to mp4", with 64 kbps bitrate & 44.1 KHz sample rate, Stereo, this is enough for Mobile phone & will give quality equivalent to a 128 kbps mp3, as mp4 is better then mp3 when it comes to Mobile phones, low file size but still high quality
Old 11-07-2005, 01:52 PM   #8 (permalink)
aadipa's Avatar
Best I have found is AAC.
Just install dBpower Music Convertor and dBpower AAC Codec. now convert your file (which is most probably MP3) to something like Quality 60~50 VBR settings.
There is no fix settings, you have to listen each song at diff. quality. Some will sound nice even on quality 40 while others will need 70.
If you are batch converting, 60 will be nice bet.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 17-07-2005, 01:23 AM   #9 (permalink)
Thanks a lot ppl.. will try all. as of now I am trying with DBPoweramp.. will try others soon.
PraKs is offline
Old 21-07-2005, 11:37 PM   #10 (permalink)
Undoubtedly ... DBpowerAmp is gud!
But .. doesnt Sony ericsson provide its own piece of software for this job?
futuristically_ancient is offline
Old 23-07-2005, 12:13 AM   #11 (permalink)
hey, im unable to play aac sound files(extension .aac, converted using dbpoweramp) in my k700i? i thought the phone supports this format, but the sound file is placed in OTHERS folder.
Athlon 64 2800+ | MSI K8M-Neo-V | Seagate 160 GB PATA | 512 MB Simmtronics DDR400 | Creative Inspire 5200 5.1 | Philips 107E5 17\" Monitor | Sony DVD-CDRW | Microsoft Internet Keyboard+Logitech MX518 | XFX Geforce 6600GT 128MB AGP |
HellGuardian is offline
- by c4u
