To free up phone memory in n86
1. delete any known large attachments from Messaging and/or Nokia Messaging
2. delete any direct downloads you've done
3. remove any trial applications you've installed to 'Internal memory'
4. use Y-Browser/xplore to delete the '\cache' folder on C:/system (deleting the cache from inside Web isn't as reliable)
5. (if a Google Maps user) use 'Options | Tools | Reset' - this frees up memory used for cached maps
6. again in Y-Browser/Xplore, delete 'C:\system\temp' , there are sometimes Megabytes of .SWF (Flash) files here
7. delete the ‘dmgr’ folder in C:\System
8. change your default ‘Messaging’ memory to either the 8GB inbuilt storage or a Memory Card. To do this, enter ‘Messaging’, hit Options>Settings>Other>’Memory In Use’
9.Open the Ovi Store application settings and make sure it is set to install applications on your E: drive. To do this navigate to Options>Account>Settings>Installation Preferences.
10. go to C:\data\wscache thn call logs n delete all...do the same 4 msgs n contacts..it does nt delete them from your phone..may be its a archive or something.
11.If you use POP email, which you shouldn’t since there is IMAP, then go into your mailbox settings and set it to enable POP for email that arrives from ‘Now’ on, this will reduce the number of old emails it downloads. I know this seems petty.
Now To free up phone memory occupied by pre installed softwares( oxford dict, themediy, wavesecure etc) without loosing them:
1. Installation files(.sis/.sisx)of softwares(like themediy,wavesecure etc) that came pre installed in phone memory is there in some folder "10202dce". Locate folder and installers inside it.
2. Reinstall wavesecure and themediy using their installers (theme diy(6 mb), wavesecure(500KB)).While reinstalling installer will ask for location to install the application. Choose e: ie mass storage memory). Application will be moved to e: from c:. This will free up around 6.5 MB of c: )
3. For oxford dictionary,(its installer not required, only requirement is gprs/wifi etc) start it and go to options->check for updates, download available update and install it. It will ask for location, opt for e: (mass storage 8gb one). Oxford application will be moved to e:.
Now for its dictionary files(4mb, installed inside c: ). Go to options->dictionaries catalogue->english dictionaries->english-english and download dictionary file to e:. ( any of the desired dictionary fille can be downloaded, i opted for eng-eng). Now go to application manager and uninstall concise oxford english..(around 4mb, dictionary file for oxford dict updated version (7.8mb) of which is now moved to e: ).
Doing this will free up around 5MB of c: (phone memory).
following above three steps, u will free up ~ 6.5+5=11.5Mb of phone memory without loosing those nice softwares.
Hope these all tips help you
