24-01-2010, 07:22 PM
Speed via 3G ??
I am using BSNL 230 unlimited plan...I am getting very low downloading speed connected via Nokia 7210 (No 3G) and my friend using the same plan but connected via Nokia 5800 (3G:HSDPA, 3.6 Mbps) and getting speed around 50-60kbps...Do 3G mobiles provide better speed or any other reason ???
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
24-01-2010, 10:12 PM
Re: Speed via 3G ??
There is a trick for BSNL, in which if you have a 3G enabled device. You just need a 3G device and a 2G SIM card, select manual network and register in 3G network or Hybrid. Now you can download at 3G speed and that to unlimited at Rs. 230.
25-01-2010, 01:06 PM
Re: Speed via 3G ??
That mean...using the trick...we can have good downloading speed...That's gr8 !!!
Tell me...using this trick...we can have same speed with different sets having 3G...or there is any effect of mobile too ??
25-01-2010, 05:21 PM
Section Moderator
Re: Speed via 3G ??
NO u cant
3G accesspoint is different from 2G
It may be temporary the bsnl guys are upgrading...so it wont last long...
get a 3g data plan
26-01-2010, 12:05 AM
AJJU
Re: Speed via 3G ??
Originally Posted by gopi_vbboy
NO u cant
get a 3g data plan
it may be  but as long as we get good speeds its always good
and Pratul 50-60 KbPS is not 3G speeds i think
I love and Live to Design
26-01-2010, 12:57 AM
New Gen Guru
Re: Speed via 3G ??
I think he is saying downloading speed is 50-60 KBps...which is equal to 512kbps speed
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
26-01-2010, 01:06 AM
AJJU
Re: Speed via 3G ??
if its KBps then ill get one BSNL sim soon
some one please confirm it
26-01-2010, 07:22 AM
CBZ is better than Pulsar
Re: Speed via 3G ??
chek ur 3G specifications: like nokia e63 supports a max of 384kbps speeds whereas nokia e71 supports upto 3.1MBps speeds
|| Beauty is to the Mind what Food is to the Body ||
26-01-2010, 10:47 AM
New Gen Guru
Re: Speed via 3G ??
Sorry my mistake in understanding  ....
BSNL 230 is a gprs plan soo he can no way get 50KBps download speed..its 50-60kbps only
Its written in bsnl site that bsnl 3g would have more then 384kbps
Photography Gears -
26-01-2010, 12:33 PM
Re: Speed via 3G ??
What does this 3.6Mbps mean in HSDPA, 3.6 Mbps ??
---------- Post added at 12:33 PM ---------- Previous post was at 12:32 PM ----------
Yes, it's KBps
26-01-2010, 03:14 PM
Re: Speed via 3G ??
3.5 mbps mean that its high speed downlink packet access which is 3.5 generation technology which enable high speed data download upto 3.6 mbps but in country upto 10.2 mbps for example motorola milestone supports 10.2 mbps hsdpa which is some what similar to enhanced data rate for gsm evolution that is edge will increase download and upload speeds in 2g . Edge is also known as 2.75g which provides speeds upto 299kbps in class 12 and 236 kbps in class 10.
Visit here for latest news http://newtechproductsreview.blogspot.com
Free Magazines Download at http://freemagazinedownloads.blogspot.com
26-01-2010, 03:23 PM
Re: Speed via 3G ??
3G means UMTS which supports only uptil 384kbps.
3.5G means HSDPA which supports till 3.6mbps.
Some fones like N73 support UMTS, but not HSDPA.
BSNL and MTNL all give HSDPA.
26-01-2010, 09:32 PM
Re: Speed via 3G ??
Actually, I have very little knowledge regarding 3G speed n all..
Tell me...which handset will provide good speed with BSNL 230 plan...
Nokia 5610 or Nokia 5230 ??
