19-12-2009, 06:08 PM
Just Do It
Bluetooth Headset
I want to buy an inexpensive, durable, Bluetooth Headset for Nokia 5800 XM. I want to accept calls using it.
Also are there any other uses of the same headset ?
Can you list any ?
Thanks
19-12-2009, 09:23 PM
New Gen Guru
Re: Bluetooth Headset
u can use bluetooth to hear audio/songs...
but it will sound like mono
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
20-12-2009, 08:44 PM
Just Do It
Ok
Can you suggest few inexpensive ones ?
20-12-2009, 08:52 PM
Bond, Desi Bond!
Charley,
What's your budget.
20-12-2009, 09:11 PM
New Gen Guru
Photography Gears -
23-12-2009, 10:30 PM
Just Do It
Originally Posted by desiibond
Charley,
What's your budget.
Looking for the minimum, but should be durable.
24-12-2009, 01:16 AM
damnbadman666
SujoYp
i bought the same for 900/- inc tax
24-12-2009, 11:48 AM
New Gen Guru
Originally Posted by damngoodman999
SujoYp
i bought these 3 months back...anyway price differ in cities
Photography Gears -
25-12-2009, 03:20 PM
Just Do It
So this is cheapest available ?
25-12-2009, 05:47 PM
New Gen Guru
not the cheapest but reliable...all other branded once r costlier...check for Jabra and Nokia for cheap and reliable bluetooths
Photography Gears -
