Old 22-11-2009, 04:01 AM   #1 (permalink)
Smile Best Earphone For My Cowon D2+
Hi Friends,
I bought Cowon D2+ black 8GB(11.5k) and surprisingly I don't find the Sound Quality as impressive as expected.Believe me my Sony Ericsson W810i sounds better.I also bought Philips SHE9800 EARPHONE upon recommendation but perhaps made the biggest mistake of my life.My bundled earphones with Cowon D2+ sound better and I mean it.I am extremely disappointed.
I listen only to Hindi Songs.Please help me in getting the best earphone which would produce sweet,soft,silky and crystal clear sound.And kindly don't recommend Philips earphone.
Thanks in advance
rohit_barker is offline
Old 22-11-2009, 07:35 AM   #2 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Default Re: Best Earphone For My Cowon D2+
^for 750 bucks, get creative ep 630.
|| Beauty is to the Mind what Food is to the Body ||
panacea_amc is offline
Old 22-11-2009, 08:13 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ep-630 is not great one. chech these
sony mdr-ex35lp
sennhieser cx-200 ll sport
desiibond is offline
Old 28-11-2009, 12:20 AM   #4 (permalink)
Smile Re: Best Earphone For My Cowon D2+
Guys,
Any other earphone that is already mentioned above.
Perhaps a sennhieser but better than cx-200.
Thanks
Old 28-11-2009, 08:53 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
do you have a price range in mind?
Old 28-11-2009, 07:53 PM   #6 (permalink)
there are a lot of earfones- wats d price?
Old 01-12-2009, 01:01 AM   #7 (permalink)
Guys,
I am ready to shell out upto 3000 bucks and a bit more if required. But it has to b just topnotch.It should do justice to the best MP3 player D2+ in terms of sound quality.And it should sound better than my w810i.
Thanks
Old 01-12-2009, 06:13 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Sennheiser CX400 should be the right one for you.
Old 01-12-2009, 06:48 AM   #9 (permalink)
Dear Friend,
How about a Shure SE210 Noise Isolating Earphone? Is it available in INDIA? And if yes where and what's the price? Or can I get SHURE EARPHONES in INDIA?
Thanks
Old 01-12-2009, 08:35 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Shure's site: http://www.shure.com/India/index.htm
SE210 is a good set of earphones but they are difficult to find in India and should be lot more expensive than CX400. These cost 90$ to 140$ in USA so you can expect how much they will cost in India.
You can also check these:
Klipsch Image S4 in-ear headphones: Inside 5k
Head Direct RE0 (if you are not bass freak, this one's amazing). Not available in India and there are dealers in Techenclave who can get this for you from USA.
review by head-fi member: http://www.head-fi.org/forums/f103/r...st-iem-383355/
anythingbutipod: http://www.anythingbutipod.com/archi...re0-review.php
techpowerup: http://www.techpowerup.com/reviews/Head-Direct/RE0
Old 02-12-2009, 06:16 AM   #11 (permalink)
Most wanted
rohan_mhtr's Avatar
I dont understand how come your w810 sounds better then the d2 . I am now using a w810 and an ipod touch 2g but the w810 nowhere comes close to the touch in terms of sound quality or loudness . I compared the sound quality of the touch with my friends D2 using my philips she9550 headphones and the d2 sounded a little better then the touch !! so there is no way you can compare the d2 with the w810 . Check if you have messed up with the settings and also crank up the volume .
Intel C2D E7500@3.5ghz 1TB*4 = 4TB HDD,4gb 800 mhz ram , XONAR-DX , Logitech Z 5500 !! HD4770,CM 500W extreme power +, Ipod touch 2g 8gb, Wave 2 .
rohan_mhtr is offline
Old 02-12-2009, 07:01 AM   #12 (permalink)
The Sorcerer's Avatar
One man's thump is another man's bass . Sound is subjective. Most probably those headphones didn't get enough burn-in period.
As for head-direct, its a chinese company who made many headphones like head direct but under different brand name (typical of those chinese company) and amarbir doesn't get from U.S. mind you, he imports it from the mainland. Do note I used the word import, head direct doesn't have proper distribution/replacement centre here, amarbir simple imports them in bulk from China and when a defective product comes up, he ships it to china and waits for the replacement to arrive. Fah33m, the guy who even reviewed RE-2, said it himself that his went kaput but he was offered something better.
Now why would a company offer something better in place of RE-2 without even asking for re-2's packaging for something that unfortunately became "defective", unless they found out that fah33m written the reviews and wanted to make sure nothing supposedly "bad" is mentioned?
http://www.techenclave.com/reviews-a...ew-140801.html
Hardware BBQ
The Sorcerer is offline
Old 02-12-2009, 08:38 AM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
that is what I suspect. there is so much of customization in Cowon D2 that a bad setting can ruin the listening experience.
@rohit, can you post the BBE settings that you are using on your D2 and also the genre that you mostly listen to?
Old 03-12-2009, 12:51 AM   #14 (permalink)
Friends,
I am in office right now and unfortunately am not carrying my MP3 player.I have already played with the BBE settings without much improvement in sound quality. I work in a call centre as a quality analyst and use the earphones to the maximum to listen to calls. Therefore you also cannot say that I haven't burnt them. The sound quality with the bundled earphones has improved considerably since the day I bought it.But the SQ with philips 9800 is harsh and hurts my ear.
Can you guys help me with the BBE settings for someone like me who listens to only bollywood music. I am looking for a soft,crystal clear output and not bassy,loud & harsh output. The BBE settings I have set is upto 5-7 for everything.
And rohan believe me my W810i surprisingly sounds excellent and better than my Cowon D2+. It lags behind only in terms of loudness.
Old 03-12-2009, 08:31 AM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Equalizer - Rock
BBE - 5
Mach3Bass - 3
MP Enhance - yes
stereo widen - 1 or 2
3D - no
Old 03-12-2009, 01:53 PM   #16 (permalink)
Most wanted
rohan_mhtr's Avatar
Originally Posted by rohit_barker View Post
Friends,
Hard to believe since i am using the same phone . But audio quality is subjective and depends on which genre you are listning to . What do you mean by harsh , is the treble too high . Why not try using your se w810 headphones without the adapter on the d2 to see the difference .
Old 03-12-2009, 02:17 PM   #17 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
Watching this thread. Have a D2+ too, was really disappointed by the ep-630 (got these), and the cx-300 (didn't get these, just heard em) as well. The default earphones were better. People tell me that the earphones need to burn in, but this didnt bring about any improvement. @desiibond, you want in-ears only? or are you open for options.
IDDQD IDKFA
Anorion is online now
Old 03-12-2009, 04:18 PM   #18 (permalink)
j1n M@tt's Avatar
Get a SoundMagic PL-30 and a Fillo E3 or E5 headphone amplifier from Lynx-india or from mediahome if you don't feel your D2 is not so good in audio processing. btw I don't understand how you are comparing D2 with w810! May be you are too used to in using in-ear type headphones of SE, so you wont feel the D2 headphones comfortable at first. And someone talked abt burn-in. It's not that you burned you headphones, it's the 'burn-in' period he mentioned, before it will perform better(mostly 11 to 12hrs of listening time).
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 03-12-2009, 06:43 PM   #19 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
^Isn't the SoundMagic series biased towards either bass or treble? Is the PL-11 drastically better than the EP-630? The PL-30s are a segment higher, but has anyone here used them?
IDDQD IDKFA
Old 03-12-2009, 08:17 PM   #20 (permalink)
j1n M@tt's Avatar
hav used PL 11....it is biased towards bass like you said. PL 30 costs above 1.5k, reviews says they are good, and not biased towards bass or treble. I said PL 30 because they are sold as combo offer with E3 or E5 in mediahome.in or in Lynx-india(they are importing as group orders). I think the Lynx is selling PL11 with E3. Their offer is good. Cheaper than on eBay or in U.S.
j1n M@tt is offline
Old 04-12-2009, 01:02 AM   #21 (permalink)
Originally Posted by desiibond View Post
Equalizer - Rock
BBE - 5
Mach3Bass - 3
MP Enhance - yes
3D - no
Great, the harshness that I was talking about has considerably reduced after changing the settings as you had adviced. Also the sound quality has become a bit softer and sweeter.Thank u dude. But got confused while changing the Equalizer to Rock and finally could not change it finally.Kindly help.
Posted again:
Dude,
I agree with you.The treble might be too high but I have no idea where to go and adjust it as I tried earlier doing the same but could not locate where the treble was to adjust.Kindly help me if you know.
I tried the earphone HPM-70 that came bundled with my W810i but the sound quality of D2+ did not improve to my satisfaction.
Last edited by rohit_barker; 04-12-2009 at 01:20 AM. Reason: Automerged Doublepost
Old 04-12-2009, 01:18 AM   #22 (permalink)
Dear Friend,
I am looking for a earphone and not a headphone as earphones are better at sound isolation.Where can I get the amplifier in Bangalore? Can I use the amplifier that you have mentioned with my Philips 9800 earphone to improve the Sound Quality ? What's the cost? Kindly express your views.
Thanks
Old 04-12-2009, 09:29 AM   #23 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Okay. Are you able to change equalizer setting by going to equlizer list and clicking on up and down arrow?
if you are getting too much treble, then lower the last two bars of the equalizer a bit and reduce BBE from 5 to 4 or 3.
When I moved from ipod nano 1g to cowon D2, I felt that the audio quality has gone down but after getting the right settings, I got lot lot better audio quality out of D2+
Even my current 5800XM is no match for Cowon D2.
Old 06-12-2009, 12:46 AM   #24 (permalink)
Thanks Dude the Sound Quality has improved considerably.
Which earphone are you using for your CowonD2+ DUDE?
And by the way how can you compare your 5800XM with your CowonD2+!
5800XM does not have even have the best Sound Quality in mobile phones.
The UNDISPUTED KING is W995 in terms of Sound Quality as you must also be knowing.
Old 06-12-2009, 07:54 AM   #25 (permalink)
Bond, Desi Bond!
desiibond's Avatar
My earphones are Sennheiser CX200 II Sport.
Old 09-12-2009, 06:23 AM   #26 (permalink)
And dude how does your earphone sound with COWON D2+?
Old 09-12-2009, 10:25 AM   #27 (permalink)
Bond, Desi Bond!
desiibond's Avatar
CX200 II Sport is bit bassy so I had to tone down bass settings on Cowon D2+ to clear the bass.
But for your budget there are better alternatives.
do remember that there is no need for external amplifier like Fiio's as Coson D2+ is powerful enough.
listen fm in mobile without inserting earphone gaurav816 Mobiles and Tablets 18 08-12-2008 03:34 PM
My review of Cowon A3 60 GB ajayritik Reviews 1 27-05-2008 02:03 PM
Is it ok to wind the Earphone wire ? ajayritik Mobiles and Tablets 9 24-10-2007 03:59 PM
Creative EP-630 earphone Ramakrishnan QnA (read only) 14 16-10-2007 10:22 AM
plz advice a good quality earphone saurabh kakkar Mobiles and Tablets 5 27-07-2007 07:54 PM
- by gforz
