Old 03-11-2009, 01:14 AM   #1 (permalink)
Question What to look for when checking out 2nd hand mobiles
Guys! I need to know what are the aspects to be checked and warning sign when checking out used mobiles. May have to buy one so need to know.
Thanks in Advance
nmenon is offline
Old 11-11-2009, 11:41 AM   #2 (permalink)
SymbianGeek
Default Re: What to look for when checking out 2nd hand mobiles
The most important part is the hardware. Check if all the keys are working. Also check the call and if external speakers are present check if they are working fine.
Visit http://flaminghorns.com
eminemence is offline
Old 11-11-2009, 11:46 AM   #3 (permalink)
Cool G5's Avatar
You'll need to check all things like battery, charger, memory card, headset etc. If all are functioning properly.
Then check keypad, call quality, loudspeakers, camera etc.
Cool G5 is offline
Old 11-11-2009, 04:09 PM   #4 (permalink)
get a box piece... else might turn out a stolen product
hackerzlab is offline
Old 11-11-2009, 05:08 PM   #5 (permalink)
hell boy
+1 try to get the bill also
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 11-11-2009, 05:28 PM   #6 (permalink)
SymbianGeek
All the points mentioned are correct. But keep in mind if you are looking for a specific model then checking out the second hand market can be a pain.
I have been hunting for a Nokia N90 from a long time but have not found even a single piece on the second hand market.
Old 12-11-2009, 11:44 PM   #7 (permalink)
Purchased a Nokia 6120 Classic, 1 year old. Got the Box, Headset and Charger. This model is not released in India but I really wonder why. Check out its specs at the link below
http://www.gsmarena.com/nokia_6120_classic-1958.php
Its price in the UK is equivalent to 8500 Rupees. The hardware matches the N73 except for the speakers and Camera and smaller screen at 2.0" but 16.7m colours. It uses MicroSD memory cards and is only about as big as the 3110Classic. It also has speed to match the S40 based phones.
nmenon is offline
Old 16-11-2009, 01:57 AM   #8 (permalink)
ANURAG SHARMA's Avatar
I think always n must purchase a second hand mobile from a trusted person or what you ever seen in known hands.....never ever go for market or discounted ones.....I think buying a cheaper one will be good option instead of buying a crap one....
BE THE BEST EITHER HACKED IN THE QUEST
ANURAG SHARMA is offline
unable to apply skin on XMMS saurabh kakkar Open Source 26 11-03-2008 05:56 PM
Compiling Error! Dark Star Open Source 9 09-12-2007 03:20 PM
Pidgin plugin problem installin Kenshin Open Source 4 26-11-2007 01:38 PM
Failed to Open /dev/rtc : Resource Busy Mplayer Fatal :( Satissh S Open Source 7 05-02-2006 01:03 AM
- by gforz
