Originally Posted by azzu
AFAIK the fone's askin PUK code right ?
call go to Nearest Dealer(ur sim cards)
they might help
His phone is not asking for PUK code.
OP must have set his security level to phone, default is none.
If you change your phones security level to phone it will ask security code when you insert different sim.
Use your previous sim or go to nearest nokia costumer care and ask them to update your phones firmware, it will automatically reset the security code to default(i.e 12345).
But they will charge Rs. 150
