Old 03-07-2005, 11:45 AM   #1 (permalink)
Default RIM LG Phone query
I have upgraded my RIM from LG 2030 to LG5230 (colour). It says that you can download the phonebook etc on the PC. But there is no mention as to how. Can anyine tell me this.
[Edited Batty] Thread splitted
When the World speaks, it speaks in UNICODE
Aijaz Akhtar is offline
Old 04-07-2005, 11:02 AM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default lg fone pc sync
dude,go 2 reliance ka website,select ur fone model,u get a link 2 dwnload the pc sync software,get it.BTW u need 2 buy a data cable,roundish 1200 buks!
gauravakaasid is offline
Old 04-07-2005, 11:47 AM   #3 (permalink)
vishal_bhatia87
Posts: n/a
Default Re: lg fone pc sync
Yes go to www.relianceinfo.com, In handsets select your phone model, Download PC Sync Software. To connect to the pc you have to buy the LG Datacable that is for Rs1200(Genuine) Rs200(duplicate)
Old 08-07-2005, 10:39 AM   #4 (permalink)
I have the data cable that isn how I access the net at home. Thanks for the advice.
Old 10-07-2005, 10:44 PM   #5 (permalink)
Default pc sync
hi
downlaod pc sync software from lgmobiles.com it is not avaiable in relianceinfo.com ok it works fine ok
bye
-praveen
prawin is offline
Old 02-08-2005, 01:03 PM   #6 (permalink)
I have been searching for pc sync at lgmobiles.com. But nor getting. Even 5130 is not listed there???
Old 02-08-2005, 02:18 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Download PC Sync for LG 5130
http://www.AskVG.com/
Vishal Gupta is offline
Old 05-08-2005, 11:43 AM   #8 (permalink)
Thanks Vishal that worked. though TOOK 2 HOURS TO DOWNLOAD AT BSNL DIAL UP.
Old 07-08-2005, 04:50 PM   #9 (permalink)
But this provides transfer and correction of your phone book, memo (seldom used) and to do (ditto) only. I had thought that it would allow to write sms faster to be sent, and also emails thru R World. And transferring wallpapers and rinbgtones from PC to phone. After all ringtones are midi files only and the wallpapers jpg, right?
