Old 29-09-2009, 12:04 AM   #1 (permalink)
rosemolr's Avatar
Default I need a good Headphone what about SENNHEISER HD 202 ?
I just bought a nokia n78 phone.i dont have earphones with it..so i'am thinking about bouying a headphone for e in 1.5 k.what do you guys think about SENNHEISER HD 202 HEADPHONES..?
Extreme Mobile Professional..Ask anything about it..
Provide you all applications in symbian java uiq platforms
**THERE IS NO SPOON***
rosemolr is offline
Old 29-09-2009, 04:22 PM   #2 (permalink)
rosemolr's Avatar
Default Re: I need a good Headphone what about SENNHEISER HD 202 ?
20 views..no reply.please suggest some
rosemolr is offline
Old 29-09-2009, 05:29 PM   #3 (permalink)
SE Freak!
venkat_chitra's Avatar
Hey, be cool ya
Somebody will reply.
And my suggestion is to buy a SoundMagic PL-30 which is a perfect fit for your mobile or any music player.
If not, then consider the ep-630 from creative. Still it's a rocking model. I got it only for 450/-
Use Ubuntu, Spread Open-source.
venkat_chitra is offline
Old 29-09-2009, 09:47 PM   #4 (permalink)
rosemolr's Avatar
thanks for your reply man..but the thing is..i have ep630 now..it works very well like you said..but i'am looking for a headphone for my home use..i want bass..and good clarity..thats y i'am looking for sennheiser..infact i need a big headphone.i mean..something other than this eard bud type.
rosemolr is offline
Old 29-09-2009, 09:48 PM   #5 (permalink)
Intel OCer
amitash's Avatar
be clear, u want headphones or earphones? for headphones and 1.5k the senn hd202 is the absolute best...i have one and i love it
My site: collegeclassroom.org
amitash is offline
Old 29-09-2009, 09:52 PM   #6 (permalink)
rosemolr's Avatar
thanks for your comment..what about its quality of sound..i will be using it for my nokia n78 and ipod shuffle..too..
rosemolr is offline
Old 30-09-2009, 12:14 AM   #7 (permalink)
SE Freak!
Arrow Re: I need a good Headphone what about SENNHEISER HD 202 ?
Yes, be clear about that. If it's headphones, then senneheiser hd202 is the best, and there are also philips models available (Don't know about the exact model name). As for earphones, the SoundMagic PL-30 is the best. It will definitely fit for your shuffle and give you clear music experience.
Old 30-09-2009, 01:37 PM   #8 (permalink)
unni's Avatar
I don't know much about music quality. I have been using Sony earphone (600 Rs.) for the last 2.5 years. I like it because of the audio quality and especially good bass. My front got a Sennheiser head phone worth 2000 Rs. when he bought a Nokia 5800 phone. I tried it, but I didn't like it. I felt that compared to my Sony earphone, its bass was very less.
Posted again:
Posted again since edit is not working.
I am not an expert when it comes to audio quality. I have been using Sony earphone (600 Rs.) for the last 2.5 years. I like it because of the audio quality and especially good bass. My friend got a Sennheiser head phone worth 2000 Rs. when he bought a Nokia 5800 phone. I tried it, but didn't like it. I felt that its bass was very less compared to my Sony earphone.
Posted again:
unni is offline
Old 30-09-2009, 06:32 PM   #9 (permalink)
Intel OCer
amitash's Avatar
The senn headphones you get with 5800 are really cheap quality ones, i personally dont like them, but the HD202 is totally different...amazing audio quality when paired with my 5800XM
amitash is offline
Old 30-09-2009, 11:00 PM   #10 (permalink)
NP : Crysis
xbonez's Avatar
Sennhesiser HD 202 are good headphones in your budget, but few things to watch out for. it has a Y-cable, which is not such a good idea as they tend to get unintentionally tugged more ofte. One sided cables are better. Replaceable ones are the best. Also, it has an impedance of 32 ohms. don't know about the n78, but the shuffle isn't built to power 32ohm headphones. So, you're basically going to get low volume output, even at max volume levels, and its going to consume ur shuffle battery a lot faster.
Personally, I use the Ultrasone HFI 780 headphones (http://www.amazon.com/Ultrasone-HFI-.../ref=de_a_smtd). they are audiophile grade headphones with very high fidelity and a replaceable cable, but also have a relatively high impedance of 35 ohms, so I don't use them with my ipod. For portable usage, I prefer earphones, and use the Monster Turbine in-ear speakers (http://www.amazon.com/Monster-Turbin...4331838&sr=1-1)
xbonez is offline
Old 01-10-2009, 12:58 AM   #11 (permalink)
Stuge's Avatar
at that price senns are good and they are bassy too
Stuge is offline
Old 01-10-2009, 12:20 PM   #12 (permalink)
rosemolr's Avatar
thanks to all ..especially to xbones..but still the confusion exists..i can't extend my budget..and also.i dont want ear bud type earphones..coz it give me head ache..when i use it for a long tym..can anyone tell whether hd202 is suitable for nokia n78..i want to make the order in ebay soon..please help me my friends..
rosemolr is offline
Old 01-10-2009, 06:23 PM   #13 (permalink)
NP : Crysis
xbonez's Avatar
go ahea and order it. it should be fine with the n78. its the shuffle that might be a little underpowered for it. The n78 can handle 32ohm headphones
xbonez is offline
Old 01-10-2009, 06:45 PM   #14 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
dont go for hd201 or hd 202 if you are buying it for your mobile, both are hard to drive models..thats wt reviews says. I have hd201, since i am using it with pc i dnt hav imepdance problem.
Better extent your budget and buy Sennheiser PX100, which will give true music quality.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 01-10-2009, 09:22 PM   #15 (permalink)
rosemolr's Avatar
confusionnnnnnn...... ..those shop guys are not ready to open the pack and to check the quality
rosemolr is offline
Old 01-10-2009, 11:01 PM   #16 (permalink)
NP : Crysis
xbonez's Avatar
my current headphones are 35 ohms and my ipod classic can drivet hem reasonably. Agreed, I don't get ear splitting volumes like I would with a pair of earphones, but by no means is the volume feeble.
The Senneheiser's are 32 ohm, so they should ber elatively easier to drive. As for audio quality, you can trust Sennheiser with that.
xbonez is offline
- by gforz
