24-09-2009, 06:15 PM
Calls while surfing GPRS
Whenever I surf net via GPRS over my lappy and data flows continously, I am unable to get calls. Caller listen " No. not reachable".This problem doesn't arise when I surf over mobile or connection reamins dormant like while chatting.. Is there any soln for this. guys plz help.
Is there anybody who knows AIRCEL free missed call alert no. so that I cud divert calls while surfing?
BE THE BEST EITHER HACKED IN THE QUEST
24-09-2009, 09:59 PM
Jack of all Trades.
Re: Calls while surfing GPRS
m also same problem.
m using idea. i think the problem lies b/w 2g and 3g services . in 2g its quite common.
and when we chat data is not transferred regularly.
solution to this is that "STOP USING NET ON UR MOBILE OR USE IT VIA WIFI .... OR START USING 3G SERVICES"
 deepikaa is too hot man.....
24-09-2009, 10:21 PM
The network is congested whenever one uses GPRS on phone that's the reason your phone becomes unreachable & SMS are received late.
No solution but not to use GPRS when you are expecting a call from someone.
24-09-2009, 10:34 PM
Om Ma Ni Pä Me Hum
I used to have prob with sony eric phone w700 while using gprs it wouldn t take calls or sms while connected . . But not with the case of nokia n73 it goes on to hold gprs connection whenever a call or sms comes so no prob
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
25-09-2009, 08:41 AM
Location: 26.6932 n , 88.423 s. Locate me on google maps
This is a limotation of gprs itself . It cant keep two connection at once . However unless you have an 'active' connection (like downloading something) your connection should be suspended and u'll get the call.
3g dont have this limitation.
25-09-2009, 11:44 AM
Swalpa Adjust Maadi
never faced problems while gprs browsing & receiving calls on either with my old motorola c168 or current w810 on Airtel
network. both
functions are normal and no interference of one on the other.
must be quality of network infrastructure.
if you have noticed this notice you will have noticed that this notice is not worth noticing
TRUTH IS OUT THERE
Do right and fear no man.
In word without walls, is windows (7) really needed?
25-09-2009, 11:50 AM
hell boy
No, no quality difference acts here! The thing is if u r downloading then u are going to miss calls and sms. If data flow is not constant like in chatting or surfing then u will most likely get calls and sms! But on 3g no problem!
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
25-09-2009, 12:01 PM
Is there any solution to hang GPRS while I got a call,so that connection pauses inbetween like as in Dial up.
25-09-2009, 02:16 PM
It should hang automatically but sometimes it doesn't.
25-09-2009, 10:24 PM
There's no way , but as mastermind have stated , unless you are having an constant connection(like downloading something large) you should get a call .
26-09-2009, 12:53 AM
Linux User
Downloading has nothing to do with Call. I am using Airtel GPRS through Nokia 3250. I never had problem. It doesn't matter if I am downloading anything or not. Tested Just now : Downloading 9MB file, called up from Landline and received a call without any problem.
26-09-2009, 06:25 AM
I also used to use airtel but when i had a download going on(usually via torrent) i usually missed calls.
27-09-2009, 10:11 AM
Not always but mostly when you're downloading some big file & are getting good speeds of 20+kbps then there is a possibility of missing calls. Being a heavy GPRS user I can say that.
28-09-2009, 11:22 PM
Thanx for all............. for your kind comments,means thats a network fault.Is there anyone who tested over 3G.
28-09-2009, 11:58 PM
This is not a problem in 3g , infact in 3g , you can simultaniously use data and call. Saw a demo video long time ago where a person was answering a call and downloading maps to use with gps together.
29-09-2009, 10:26 AM
hell boy
I use to answer calls and download torrents simultaneously. Even use sms also!
29-09-2009, 11:34 AM
SMS can be sent anytime, normal call, GPRS or even 3G.
29-09-2009, 01:18 PM
hell boy
Sms or voice call hangs up the connection on gprs or edge! But they wont do that on 3g? I dont know what is the confusion going on with u guys over this simple thing!
29-09-2009, 08:30 PM
#19 (permalink)
SMS do hang but it is only for a spilt second but with call its next to unlimited. Sometimes on receiving a call & putting it down after a long time might result in the GPRS getting terminated.
