Old 16-09-2009, 10:32 AM   #1 (permalink)
Addicted to Gaming
AVSEQ's Avatar
Default Best brand for microSD cards
Hi, one of my friends is willing to buy a 4 GB microSD card for his Nokia 5130. What will be the best brand he should go for? Is it Sandisk or Transcend or any other brand?
AVSEQ is offline
Old 16-09-2009, 10:34 AM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: Best brand for microSD cards
Kingston
i got many of them works fine
I love and Live to Design
azzu is offline
Old 16-09-2009, 10:52 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
the quality does not depend on brand.
every brand have different models of SD cards.
value cards have very low speed and you can pick any of the brands.
but if you can burn some money, look for High speed cards like these:
http://www.transcendusa.com/Products...o=1&Func2No=13
http://www.ocztechnology.com/product...y_memory_cards
desiibond is offline
Old 16-09-2009, 11:42 AM   #4 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
I've been using various sandisk cards including some CF ,SD & microSD For years and i none have given me problem.
Kingstone is also good.
I'd strongly suggest against transcend.
Tamoghno is offline
Old 16-09-2009, 11:55 AM   #5 (permalink)
Cool G5's Avatar
Agree with desiibond. Even my local brand works fine & hasn't popped up in 2 years & still going strong.
If you still want a brand name, I would suggest Sandisk.
Cool G5 is offline
Old 16-09-2009, 06:51 PM   #6 (permalink)
there is a sandisk class 4 4GB card that i purchased for 650 a month ago for my previous fone (5320) ... fast file transfer... u can go for that ...
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline
Old 18-09-2009, 03:07 PM   #7 (permalink)
Addicted to Gaming
AVSEQ's Avatar
Well then, going for a Sandisk one.
One more query.. I found from the Nokia website that this phone (Nokia 5130 XpressMusic) supports max upto 2 GB. However, on many sites and forums (such as this one) I found that it can support even 8 GB memory. Have anyone tried using more than 2 GB with this model?
AVSEQ is offline
Old 18-09-2009, 04:12 PM   #8 (permalink)
Cool G5's Avatar
If it supports SDHC cards then it could very well support an 8GB one. Try before buying. Companies most probably hide these facts so that the consumer cannot exploit the advantages & upgrade to a new handset. Sometimes its done as the phone becomes slow on accepting higher capacity memory cards.
Cool G5 is offline
Old 19-09-2009, 07:52 AM   #9 (permalink)
5130 certainly accepts 8 gb card. I've tested it.
Tamoghno is offline
Old 19-09-2009, 08:04 AM   #10 (permalink)
Indidiot
Plasma_Snake's Avatar
SanDisk and Verbatim are really good but Kingston is more easily available and cheaper.
I use Verbatim 4GB MicroSD in my E51.
Plasma_Snake is offline
- by gforz
