Old 22-08-2009, 12:10 AM   #1 (permalink)
The assaulter
piyush.ml20's Avatar
Question memory card not accessible thru card reader
i m having a nokia n70 mobile phone.when i tried to transfer data into memory card thru card reader i got permission problm.the card is write protected.i have applied no passwd on it.i format it 4m my phone.but still unable 2 transfer data.
is default nokia memory cards can't be accessed thru card reader ?
hlp ?
piyush.ml20 is offline
Old 23-08-2009, 05:37 PM   #2 (permalink)
The assaulter
Default Re: memory card not accessible thru card reader
nobody can help in the matter plz ?
Old 23-08-2009, 09:03 PM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
friend check 2 things
1. If u are putting it into somekind of holder and then putting it into card reader then check that if it have a lock..I have seen a small lock on microsd holder which come with microsd card...
2. does ur card reader have any locking option like that
what i told is by my exp. I doono more
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline
Old 23-08-2009, 09:16 PM   #4 (permalink)
The assaulter
buddy i m using card without holder n my tech-com 36 in 1 card reader also doesn't have any lock mechanism.
is it not possible to access nokia memory cards thru card reader ?
Old 27-08-2009, 09:12 PM   #5 (permalink)
The assaulter
thx sujoyp the problm solvd.it is due to vista security.
the card works f9 in xp.
Old 27-08-2009, 11:16 PM   #6 (permalink)
New Gen Guru
sujoyp's Avatar
good that ur problem got solved
Photography Gears -
sujoyp is offline
Old 29-08-2009, 02:27 PM   #7 (permalink)
The assaulter
thx 4 ur support dude too.
- by gforz
