04-07-2009, 10:01 PM
TopTrix
gprs, pc & mobile!
i dont know if its leagal. but if yes pls help.
i have working gprs mobile connection. the data plan i subscribed only support browsing on mobile only and not to connect to pc. is there any hack or trick to use the "SAME" gprs data plan to surf on pc.
service provider donot support to connect pc.
05-07-2009, 12:27 PM
TopTrix
Re: gprs, pc & mobile!
is it not possible. pls help.
05-07-2009, 03:33 PM
Which service provider U r using?
http://amirphp.wordpress.com
06-07-2009, 02:02 PM
TopTrix
Reliance GSM
06-07-2009, 02:16 PM
TopTrix
atleast tell me is it possible or not. pls reply.
06-07-2009, 04:01 PM
Om Ma Ni Pä Me Hum
I used to try with opera . .
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
06-07-2009, 04:19 PM
Using WAP on PC is not worth the trouble you take. Each page load at snail's pace. You are better off using broadband or GPRS on PC.
06-07-2009, 08:57 PM
TopTrix
i have managed to open opera mini on my pc with microemulator. u got it. now tell me the answer me the original qustion.
09-07-2009, 12:21 PM
It's simple. Configure proxy in your browser & connect using PC Suite.
10-07-2009, 06:59 AM
TopTrix
how? please give me details or link.
10-07-2009, 01:13 PM
Hello mate
Am using BPL/loop mobile for my pc to browse internet.
Yes its possible to connect to net usin your handset as modem, not sure about being legal as loop mobile call centre says "no sir we do not provide this service" but after tweaks you can connect  .
just make sure you have unlimited data plan, else be prepared to burn your wallet!
10-07-2009, 03:22 PM
geek........
It's easy to connect PC with wap.
If you have wap connection then you have to know two things
1. It's access point
2. proxy & port(usually 8080)
if you know these i can try to help further
10-07-2009, 09:02 PM
Originally Posted by montsa007
Hello mate
You on Prepaid or Postpaid? AFAIK Loop only provides WAP for Prepaid users.
10-07-2009, 10:30 PM
I said i'm on prepaid, 10 ka gang card, not sure if its still sold. Yes they only provide wap for free but if you fondle a bit you can get free internet on your pc
11-07-2009, 12:13 PM
Help to connect my iPod to internet. I have BSNL SL2_141 Modem.
11-07-2009, 05:43 PM
Ok here is the trick...
Download a software called Joiku Spotlight...and you can use it via Wifi..only
12-07-2009, 08:20 AM
TopTrix
yet no one telling detail procedure. please here r all details.
service provider: Reliance gsm
plan: day pass plan rs.10/day
only gprs on mobile not on pc. i want to use it on my pc. how. is it possible. if yes pls give detail procedure not advice.
12-07-2009, 10:47 AM
geek........
^^^Which phone you are using to connect?
12-07-2009, 01:03 PM
#19 (permalink)
and this plan will be too heavy on pc...Because it has limitation of 10 mb only.
Loading heavy sites loss of more data.
If you have nokia:
1. Install pc suite
2. After finishing it when you connect mobile mobile, mobile icon in taskbar will glow. Right click on it and choose "connet to the internet".
3. Clink on setting >choose modem>manual setting.
4. In the APN fill: rcomwap
and click finish.
Now open your browser and give the following proxy:
proxy: 10.239.221.5
port: 8080
Now connect to the internet. This worked for me.
12-07-2009, 05:58 PM
#20 (permalink)
TopTrix
i have managed to open "opera mini" yes opera mini on my pc to reduce traffic. mobile is sony ericsson w700.
thanks Amir.php. my pc got connected to internet. atleast the pc show like that. all got ok. but i cant open any website.
16-07-2009, 08:30 PM
#21 (permalink)
TopTrix
i finally have connected with internet. but not any page is opening. why. pls help.
how i did it.
mobile: se w700
service: reliance gsm
plan: day pass. plan only support gprs on mobile not to connect to pc. but i connected with pc and connection established but no any paid is opening. why. pls help.
16-07-2009, 10:12 PM
#22 (permalink)
I too am enjoying their free WAP but I think they don't offer GPRS for prepaid user, atleast that's what the CC guy told me.
17-07-2009, 10:18 AM
#23 (permalink)
To open page configure proxy in browser, which i have tell you previously.
17-07-2009, 06:33 PM
#24 (permalink)
TopTrix
i have done all that but still that problem pls help.
17-07-2009, 07:41 PM
#25 (permalink)
tHe nEw gEEk......ITian
See, if the web page is not opening after configuring proxy too and its showing that u r connected to the network. Then u cant simply use it..........as they (reliance server end) have blocked the gateway so that u cant connect ur phone as modem on pc.
They have other services with which u cant connect. Earlier it was possible but there is no hack currently available.
19-07-2009, 05:40 PM
#26 (permalink)
TopTrix
thanks all for ur reply
25-07-2009, 05:46 PM
#27 (permalink)
TopTrix
thanks all for ur help. by the time i understood that its not possible.
28-07-2009, 07:16 PM
#28 (permalink)
hey guys
i have a slight problm with ma pc. whenevr i start it the processor light blinks rapidly. the blinks go on for about a minute after which the computer boots up. i opened up the case to check if the fan is malfunctioning. but it was working fine even before the PC booted up. is there some problm with my PSU?????
PLZ hlp
Digit RoXXX!!!!!
28-07-2009, 09:56 PM
#29 (permalink)
^Make a new thread.
30-07-2009, 11:48 PM
#30 (permalink)
I remeber reading it somewhere in this forum. Tuts ?
