01-07-2009, 06:56 PM
Angootha Chaap
Cost of 8GB / 4GB Micro SD Card?
Simple query. I tried to search for it but couldn't find a new enough post on it.
EDIT
Found this:-
8GB mem card help
JUst need an update on prices now. Everything I wanted to know is in the above thread!!!
Angootha Chhaap
Reason: inserting link to a relevant thread
01-07-2009, 09:12 PM
Location: 26.6932 n , 88.423 s. Locate me on google maps
Re: Cost of 8GB / 4GB Micro SD Card?
Got 8gb for 850 few weeks back , dont know about 4gb.
02-07-2009, 10:39 AM
want to buy a 16gb M-SD/hc CARD. Any 1 know how much it will cost ?
02-07-2009, 10:46 AM
Which brand and where ?
04-07-2009, 08:03 PM
Angootha Chaap
Yeah! Which Brand and Where?
Angootha Chhaap
04-07-2009, 09:29 PM
Original sandisk and got it locally . Its surely original because it was already replaced.
04-07-2009, 09:44 PM
TheSaint
I thought 8 gb is 1300
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
05-07-2009, 11:53 AM
Does it came with that usb micro card reader?
05-07-2009, 12:29 PM
The Master Chief
8gnb cards are microsdhc right??i was planning to get one for my n82 phone too...does anyone know whether it supports microsdhc
05-07-2009, 12:56 PM
N82 does support micro sdhc .. it supports upto 32gb . I am using my N82 with 8gb without any issues.
05-07-2009, 02:10 PM
No it dont came with that card reader . I think the newer batch dont comes with card reader and hence the reduced price. Older card reader bundled ones are around 1.3k , i also bought a writex card reader @ 210 and it supports sdhc and microsdhc cards without adapter .
05-07-2009, 08:43 PM
Tech Addict
@Saurabh,
Check your PM.
05-07-2009, 08:49 PM
Tech Addict
@Saurabh,
Check your PM.
06-07-2009, 02:03 AM
The Master Chief
Oh ok thanks a lot man..will surely buy it then
06-07-2009, 02:00 PM
Gracias Senor
I checked Reliance digital in Gurgaon..Transcend 4GB is 599 and Sandisk 4GB is 999. Actually went to check the price for 8 or 16GB. But not avail.
Why is this price difference..and which brand is gud. I own a Touch.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
06-07-2009, 04:17 PM
The price difference should not be more than rs30-50 . 999 is robbery for 4gig. Check somewhere else .
07-07-2009, 02:33 AM
i jst bought a 8gig
4gb sandisk 480
8gb 800-850 (shop to shop,,,,)
