AFAIK blackberry dont have proper exchange support for email . They only work with something called BES . I dont have much experience about emails on blackberry so i may be wrong, but i'd recommend you to check out if blackberry is fully compatible with your email. Also i haven't heard much good things about blackberry music quality.
I personally dont like the form factor of e75 , i also think its way overpriced . Also the keypad is not the most comfortable because the keys have almost no gaps .If i were you i'd choose e71 . Its a pretty SOLID AND RELIABLE device . I have read about true story about it almost working even after run over by car and being (accidentally) washed in washing machine.
If you need music +email then nothing could be better than nokia 5730. Xpressmusic phone with e75 like slide out qwerty .should be releasing very soon. Also consider it.
