Old 14-06-2009, 10:20 AM   #1 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default Nokia 3110c does not switch on
Last night i used net on my phone. It was fine. In the morning i saw it was switched off. It just does not switch on. My phone.s battery is fine. I checked. Even when i changed the battery it does not switch on.what is the problem?my phone is a year old. Is this a common problem with 3110c.
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 14-06-2009, 10:56 AM   #2 (permalink)
New Gen Guru
sujoyp's Avatar
Default Re: Nokia 3110c does not switch on
just go step by step...
1.try some other nokia Bl5c battery in ur phone
2. Put ur Battery into some other phone
3. Check wether ur charger is working properly
if all fail go to Nokia care
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline
Old 14-06-2009, 11:18 AM   #3 (permalink)
damn busy...
utsav's Avatar
If evrything fails then dump it into nokia's recycle bin
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 14-06-2009, 01:02 PM   #4 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
Does the white backlight turn on ? Try what sujoyp said and also try removing memory card and sim.
Tamoghno is offline
Old 14-06-2009, 01:45 PM   #5 (permalink)
tHe nEw gEEk......ITian
pr.itdude's Avatar
Lightbulb Re: Nokia 3110c does not switch on
one often face these kind of problems with Nokia 3110c.....Around a month ago, i faced similar kind but not such bad problem..........My phone often restart, once or twice a day......so i knew i had to go to Nokia Care and get the firmware reinstalled......
But suddenly it became fine..........and there is not any kind of problem now....!!!
It seems, there is some hardware problem in ur phone........better go to Nokia Care. !!!!
pr.itdude is offline
Old 14-06-2009, 04:02 PM   #6 (permalink)
jatt's Avatar
Restart or booting problem, is common problem in nokia model 3110c.i will suggest you just take off memory card and try to switch it on.then write here results.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 18-06-2009, 12:54 PM   #7 (permalink)
^^ tried it to no effect.
took my phone to one mobile shop they say that the phones software's corrupt. looks like i will have to go to nokia care. isn't there something i can do? like install the software myself.
Old 19-06-2009, 01:54 PM   #8 (permalink)
Tech.Masti's Avatar
Is this under warranty? Then go directly nokia care
Tech.Masti is offline
Old 20-06-2009, 01:04 AM   #9 (permalink)
just gave it to nokia care
- by gforz
