13-06-2009, 06:04 AM
Best EARPHONE for my COWON D2+
Guys,
I purchased COWON D2+ yesterday.Please suggest me the best earphone available for it in bangalore.
BUDGET-2000 BUCKS
13-06-2009, 05:41 PM
Re: Best EARPHONE for my COWON D2+
how much did the d2+ cost
13-06-2009, 07:29 PM
Bond, Desi Bond!
@Rohit, Congratulations for getting D2+. Inside 2k, my suggestion would be
1) Sennheiser CX300
2) Sony MDR EX-76LP
3) Sony MDR EXP-35LP
15-06-2009, 11:35 PM
It costed 9300 bucks has 8gb memory.
@desibond
which is the best out of the three mentioned?
1) Sennheiser CX300
2) Sony MDR EX-76LP
I want to purchase SONY earphones.They are damn good.SONY ERICSSON A series mp3 players sounds very good.
which is the earphone that comes with SONY ERICSSON A series mp3 player and how much does it cost?
15-06-2009, 11:57 PM
Bond, Desi Bond!
if you really liked Sony earphones, then you can go for MDR-EX55LP or EX-76LP. EX-76LP is near to 2k but is a worthy buy. Don't go for Creative EP-x30. They are too bassy and not good for the clean audio that Cowon D2+ gives.
16-06-2009, 12:49 AM
the senheisser pmx100 is far more better than any sony earphone mentioned here(its a neckband headfone,best for traveling purpose),i send u a PM..plz check,
if u want u can contact me to have a look at my pmx100 and listen to its sound quality before buying any earphone!!!
16-06-2009, 01:19 AM
I am looking for a clean audio experience and not an earphone which has more bass.
I am looking for earphones with excellent sound quality and yea, i just want something thats very clear and clean. basically a very balanced phones, no super bass either.I can expand my budget to 3000 bucks.
16-06-2009, 09:18 AM
Bond, Desi Bond!
PMX100 are too sweet sounding. I would prefer CX300 over this one!!
16-06-2009, 06:07 PM
Most wanted
You wont require headphones with higher bass ratio , the d2 provides ample bass on any normal headphones . From the above mentioned headphones i am using sennheiser cx300 and they are very decent and highly comfortable . i use them with my ipod touch for as long as about 6 hours but still my ears do not pain .
16-06-2009, 09:30 PM
the cx 300 is a good one..The main problem i face using earphone is that my ears starts paining after half an hour of using. Though it may differ from person to person..so i always prefer headphones or neckband types which are very comfortable for long time listening.
16-06-2009, 09:43 PM
Guys I am looking for a earphone that gives me crystal clear sound experience.I should be able to listen to most of the intruments distinctly and clearly used in a song.I hav heared cx300 is bassy.Any other better than this?
17-06-2009, 12:35 AM
Location: 26.6932 n , 88.423 s. Locate me on google maps
Try philips . They are one of the most clear earphones i've heard. try to find shh9700
17-06-2009, 12:03 PM
+1 for Philips.Very balanced over all frequencies.I personally use SHE-9501.So i'm quite sure of its sound quality.
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
25-06-2009, 06:22 AM
So finally which one do you guys suggest?
should simply be the best.Am ready to increase the budget if required.
I doubt if a philips earphone can be better than a sony ericsson or a senheisser.
But really can't say anything as I have never tried a philips earphone.
I am looking for a sweet crystal clear sound.
25-06-2009, 09:22 AM
Bond, Desi Bond!
@Rohit, I would pick among Sennheiser and Sony. Philips is good in making full sized headphones and speakers but for in-ear headphones, it's Sony/Sennheiser.
25-06-2009, 11:51 PM
So my friend which earphone would u suggest for my COWON D2+?
Should be available in india
BUDGET-3000 BUCKS
