Old 29-05-2009, 03:54 PM   #1 (permalink)
Question breaking lock code of nokia 3600 slide
guys i have forgotten the lock code of my nokia 3600 slide.
Now i can't insert another sim in my mobile because i have enabled "lock if sim changed"
Please tell me any another master code or way so that i can change or break my lock code.
Guys pls help me out!!!!!!!
anant197 is offline
Old 29-05-2009, 03:59 PM   #2 (permalink)
Location: 26.6932 n , 88.423 s. Locate me on google maps
Default Re: breaking lock code of nokia 3600 slide
Take your phone to nokia care with cash memo.
Dont search for master codes . Newer nokias are unhackable.
Tamoghno is offline
Old 01-06-2009, 03:58 AM   #3 (permalink)
use mastercode software , you can easily found it over the internet, install it on your fri symbian phone, enter your imei and you will get a master code.
I wont ask your imei coz people will think this is scam..so do it yourself.. !!
@Tamoghno its funny that nokia keeps on developing firmwares that are unhackable..new firmwares can be hacked easily..... !! never under estimate yourself !! trust me !!
neerajvohra is offline
- by Anorion
- by ax3
