| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
n also wil updating my firmware help?? mi major concern is d backup..coz d formattin can be done in d nokia service centres!! pls repli at d earliest.. thnx in advance 2 al! PEACE!
P4 @ 3.4Ghz, 2Gigz ddr400,Intel 945g, 512MB GeForce 7900GT, Viewsonic 19", 320 Gigz WD Sata2, HP 20x dvdrw,Windows Royale |
#2 (permalink) |
download the latest nokia pc suite .... connect ur fone and go to backup manager .... u can back up all ur contents ( both fone and mem card) .... contacts msgs notes pics vids everything ... then using update manager see if there is a new version ... update ... then format ur fone and mem card ... connect it back ... restore ur data
Acer Aspire 5536 X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200 LG O1 (CM7 beta6.5 LG o1 owner ?... update ur detailshere |
#3 (permalink) |
reli appreciate dat..buh 1 prob i found is dat..i got folders 4 mi msgs..des folders r not included in d bakup using pc suite..n wen i merged al d msgs in2 d inbox..(a total of 2500)it failed 2 access!!so dis is d dilemma m facing..nw i cant change 2 d mem card coz of sme error!!
pls advice furhter! thnx 2 u!
#4 (permalink) |
pls advice furhter! thnx!
#5 (permalink) |
Jatin
Oh for gods sake dont tell its due to RAM or Firmware issue Or due to VIRUS.
The error message was "Phone Memory Full".and not "Memory Full Close some applications" another problem which is due to Low RAM This issue has been discussed here in this community lots of times, i guess few have been deleted. Here are the reason for that . 1)Cache Folder 2)Lifeblog Database 3)Bluetooth received messages stored in inbox 4)FOTA file(reserved.bin) 5)Default Application installed in Phone Memory. 1)you can delete the cache folder content in path C:\Cache. 2)whenever you receive songs/photos/videos this lifeblog.db collects all datas and eats up phone memory. just delete lifeblog.db in path C:\DATA\lifeblog\Database\Lifeblog.db 3)you can change message storage memory as "Memory card" so that files received through bluetooth is stored in memory card directly. select messaging--->select options--->select settings--->select other--->select memory in use and change it to "Memory card". 4. you can delete FOTA files (which occupies 5MB of phone memory). c:\PRIVATE\102072c4\reserved.bin which is used for FOTA and not used as of now. This file eventually comes back whenever you format the phone or check for firmware upgrade throuch Device Manager in Tools. 5)Applications like "Settings wizard" and "Search" is installed in phone memory which occupies 3MB approx, you can uninstall both application and install it in memory card. If you do all the above procedure you can get upto 42MB of free phone memory. If you feel the above procedures are too long just format the phone memory using code *#7370#. Hope no one creates a topic on this issue again.
| HP dv6 6044tx | quad core i5 sandybridge | 8gb ddr3 | AMD Radeon HD 6490M (1 GB DDR5) | 500gb HD | | Samsung Galaxy S2 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
