Old 26-05-2009, 03:21 PM   #1 (permalink)
varuog's Avatar
Lightbulb Best 50k lappy?
Hii friends ...
I am back here after a long time ... Had to make a new id as I've lost my previous account.
Anyways, coming back to the topic, I am once again in dire need of your help. (I was advised to buy n82 in my previous query and I am glad I went with your advice).
Now, I need to buy a laptop - my first ever ! My budget is around 50k.
I am not very sure about the configuration. I'd just like to have the best in my budget.
I prefer to buy Dell or HP.
Since I am a student, I'll be needing the lappy for various purposes - includes programming, movies, little bit of gaming etc ...
Can you please advice me a suitable choice?
Thanks in advance !!!
varuog is offline
Old 26-05-2009, 03:26 PM   #2 (permalink)
S60 rocks
rajhot's Avatar
Default Re: Best 50k lappy?
Dell Studio 15
Proud Owner of N82!
rajhot is offline
Old 26-05-2009, 03:37 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I couldn't think of anything other than Dell Studio series.
desiibond is offline
Old 26-05-2009, 03:44 PM   #4 (permalink)
varuog's Avatar
can you pls tell me the price of dell stdio 15?
secondly, i was just browsing and found dell studio xps series quite impressive! what do you all think about them? can anyone pls confirm me its price (in india)?
varuog is offline
Old 26-05-2009, 03:55 PM   #5 (permalink)
S60 rocks
rajhot's Avatar
You can configure Lappy in dell site according to ur requirements...finally it'll give u thr price also.
Proud Owner of N82!
rajhot is offline
Old 26-05-2009, 04:09 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
studio xps I think costs around 60k but is one hell of a laptop.
Old 26-05-2009, 04:32 PM   #7 (permalink)
varuog's Avatar
^^^ 60k ??? Sad !!!
I can extend upto 55k but .... 60k is way out of my budget ...
varuog is offline
Old 26-05-2009, 04:39 PM   #8 (permalink)
S60 rocks
rajhot's Avatar
then go with studio 15
Proud Owner of N82!
rajhot is offline
Old 26-05-2009, 05:40 PM   #9 (permalink)
varuog's Avatar
There's even one Studio XPS 13 - and it's priced around 54k (I am not sure, though).
What about it?
varuog is offline
Old 26-05-2009, 07:45 PM   #10 (permalink)
Studio XPS laps have serious heating issues
a55a55in is offline
Old 26-05-2009, 08:06 PM   #11 (permalink)
damnbadman666
damngoodman999's Avatar
STudio 15 is good laptop , even i suggested for many of them past one week in my place 3 of them got same problem , not with performance issues but - DVD DRIVE thats the only problem .
MANY TIMES ITS NOT WORKING !! gr8 !! look forward for that one , clear ur clarification with the dealer about the warranties & get .
Check for the ASUS laptops with same config as DELL studio 15 it comes with the 9700MGT GPU costs 57K . i asked today only !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 26-05-2009, 09:18 PM   #12 (permalink)
New Gen Guru
sujoyp's Avatar
keep ur 5k extra for additional warranty...every lappy need it
Photography Gears -
Nikon D3100 DSLR , Nikkor AFS VR 18-55mm , Nikkor AFS VR 55-200mm , Nikkor AF 50mm 1.8 , Nikkor AIS 55mm 2.8 Micro , Tamrac Velocity 6x Bag
Yougnou YN-465 flash , Vanguard ESPOD 203AP
Check my Best pics at -> http://500px.com/sujoyp
sujoyp is offline
Old 28-05-2009, 06:00 PM   #13 (permalink)
varuog's Avatar
Guys can you tell me the diff between windows 32 bit and 64 bit and also between ddr2 and ddr3 RAM ?
Which one is better in each?
varuog is offline
Old 03-06-2009, 08:59 AM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
32-bit OS can access a max of 3.25Gb of RAM. 64-bit can access 16 exabytes of RAM.
DDR3 advantages over DDR2:
1) Higher bandwidth
2) Higher frequency
3) lower operating voltage
DDR2 advantages over DDR3:
1) Lot lot cheaper
2) lower latencies
3) cheaper compatible motherboards
Old 03-06-2009, 10:26 AM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get this instead:
Dell Studio something
Costs 43k, if u make ram 3GB from 4GB, it will cost lesser. GPU to HD3670 and procc to C2D P8400 online customization will take to price to near 50k(lesser).
http://pleaseguide.me/
comp@ddict is offline
Old 03-06-2009, 11:40 PM   #16 (permalink)
varuog's Avatar
even i am thinking to buy dell studio 15.
just 1 last query .... what one should i prefer - windows 32 bit or 64 bit ????
varuog is offline
Old 04-06-2009, 09:09 AM   #17 (permalink)
Bond, Desi Bond!
desiibond's Avatar
that depends on applications that you use.
Post the list of apps that you are going to use.
Old 04-06-2009, 11:38 AM   #18 (permalink)
Point Blanc
u wont get XP but Vista, on Dell site u will need 100 bucks extra for 64-bit OS, but sadly soon Vista will become totally obsolete. 64-bit OS supports 32-bit apps, so you can go for 64-bit Vista Home Premium without thinking.
acewin is offline
